lubracali Posted January 9, 2011 Posted January 9, 2011 Hello I wrote this code to create pdf from a design by specifying which area of the drawing must be printed. The code works, but the file is always in the format "A4". How can I define a custom format with vba, that is not present in the default format for the printer? Each print has a size different from the others and I wish the paper was the same size and proportions of the printed design. I hope I explained myself well because my English is bad. If not I'll try to explain better This is the code Private Sub cmdPdf_Click() Dim stampa As AcadPlot Dim nBACKGROUNDPLOT As Long nBACKGROUNDPLOT = ThisDrawing.GetVariable("BACKGROUNDPLOT") nBACKGROUNDPLOT = ThisDrawing.GetVariable("BACKGROUNDPLOT") Dim num_prova As Integer Dim x_origine As Double Dim y_origine As Double Dim origine_testa_y As Double Dim ptA(0 To 2) As Double Dim ptB(0 To 2) As Double Dim puntoA As Variant Dim puntoB As Variant num_prova = txtNumProva.Text x_origine = 200 + (num_prova * 200) y_origine = 200 origine_testa_y = y_origine + 62.5 ptA(0) = x_origine + 14.4325 ptA(1) = y_origine + 7.1914 ptB(0) = x_origine + 104.4325 ptB(1) = origine_testa_y + 51.7515 puntoA = ptA puntoB = ptB ThisDrawing.ActiveLayout.CenterPlot = True ThisDrawing.ActiveLayout.StandardScale = acScaleToFit ThisDrawing.ActiveLayout.GetWindowToPlot puntoA, puntoB ThisDrawing.ActiveLayout.PlotType = acWindow Set stampa = ThisDrawing.Plot stampa.PlotToDevice ("Adobe PDF") Call ThisDrawing.SetVariable("BACKGROUNDPLOT", nBACKGROUNDPLOT) End Sub Quote
