Hi All,
I am a beginner in LISP...
I have a problem which pressures me to find a quick solution...'
Is there a method to get the insertion point of each block matching a given name inside an XRef in the current drawing?
I have a sheet file, say 'FileA'. The Furniture layout, say FileB, is an XRef in FileA. I have to tag every furniture. But the blocks for the tag should be placed oin the Sheet File (FileA) only. A code is associated with each furniture as an invisible attribute. I have a block for the Furniture Tag, say the block name is "Furn_Tag" , with an attribute, say 'Furniture_Code', which has to be extracted from each furniture block inside XRef. Then this
Is there any solutions? Anything will do.A VBA Routine or a Lisp Routine...
Please help.
