facet in CAD
Facet: A three or four sides polygon that represents a piece (or section) of a 3D surface.
On a certain CAD-related webpage I found "facet" defined as above. Is it correct? Generally "facet" is not defined this way.
facet: http://www.thefreedictionary.com/facet
Please help.
In all (except solid modelling) 3d creations ACad uses similar things, but calls them faces. The command to draw one at a time is 3DFACE - you're asket for 3 or 4 points, then for the next 1 or 2 points to continue the next face.
Other ways of doing such in one go is to use PFace / 3dMESH / EdgeSurf / RevSurf / RuleSurf / TabSurf.
Using the newer solid modelling you generally don't get faces - you end up with regions, which may be curved (e.g. a cylindrical / spherical region). Though it "shows" them faceted according to some of ACad's settings - this is only to improve 3d graphics performance - it's not actually drawn as such.
