I have this beam saddle and I needed to copy 2 of the holes. So I used Copy Face. It copied the face but it didn't create a hole in the side plate. I tried Subtract, Extrude, Intersect.
new block.dwg
When you did that you ended up with two surfaces. You weren't expecting that now were you?
after copying the face I was hoping for a hole. But I got my solid (unchanged, really) and a separate tubular face.
You must have deselcted the remainder of the rectangular face. The "separate tubular face" as you call it is in fact a surface. Check its properties if you don't believe me. And forget using the Convert-to-Solid command as it won't work.
In the time it took you to create this thread and respond you could have created the remaining two holes.
yes, i drew a circle and push-pull. So am I to assume that Copy Face simply does not work like I expected it to. If it did, it would be faster than Circle, push-pull, and this thread.
The complaint department is down the hall and the second door on the left. Don't knock; they're expecting you. Speak to Mr. Idgas. Send him my regards. LOL Really, I'm just kidding.
What can I say though? I didn't write the program. I suggest you add this feature (copy portion of a solid) to the AUGI wish list. Maybe AutoDesk will incorporate it in release 2013 if you hurry.
  • 3 weeks later...
yeah though they will probably realease autocad 2013 6 months before 2013
