David81 Posted January 13, 2011 Posted January 13, 2011 Hi, I am new to Inventor. I am trying to animate two components. I need the components to move in an axis other than major axis. Basically I need the two hinged halves of a pipe to open while the pipe has a double batter. I am trying to animate in Inventor Studio. I am only getting the pipes to open along the major axis even though I am using a constraint. Quote
JD Mather Posted January 13, 2011 Posted January 13, 2011 Zip and attach your assembly here. Did you go through the Help>Learning Tools>Tutorials? There is additional information if you search Google on Bill Bogan Inventor Studio Tutorials and here http://au.autodesk.com online classes. Quote
David81 Posted January 14, 2011 Author Posted January 14, 2011 This is what my assembly looks like. I just browsed the Inventor Tutorials. ( I guess I should go through them). I will look at the additional resources that you pointed me to. Thanks. My assembly can be found at: http://www.4shared.com/file/j8XB8-mO/Inventor_Drawings.html Quote
David81 Posted January 14, 2011 Author Posted January 14, 2011 (edited) After doing some testing and going through AU. I realised that I have a constraint problem.. I am not understanding how to use angle constraint property. Edited January 17, 2011 by David81 Quote
