Randolph Posted January 14, 2011 Posted January 14, 2011 Hi, does anybody have a (presumably short) piece of code doing the following: Command: rx (rotate aoround x-axis) does: rotate3d with x-axis pre-chosen as rotation axis and ry, rz Thanx! Quote
Randolph Posted January 17, 2011 Author Posted January 17, 2011 Sorry Lee Mac, I don't get the point in vla-rotation. I'm talking about rotation around the 3 main axis. rx shall rotate around x-axis, ry around the y-axis, rz ... You just choose 1 point to rotate around. It's just about sparing 1 option in the rotate3d command. Quote
Lee Mac Posted January 17, 2011 Posted January 17, 2011 Sorry Lee Mac, I don't get the point in vla-rotation.I'm talking about rotation around the 3 main axis. I know you are, which is why I suggested vla-Rotate3D (vla-rotate3D <object> <point1> <point2> <angle>) Where and are the two points defining your axis of rotation. Quote
BIGAL Posted January 18, 2011 Posted January 18, 2011 I think you should look at the command version first "Rotate3d" understand how that works and then re-read Lee's answer particuarly using points rather than X Y Z 0,0,0 1,0,0 is a direction in the x axis but you need a point on your object to start. Quote
Randolph Posted January 18, 2011 Author Posted January 18, 2011 I feel like I'm writing chinese Bigal, I really do know my Euclides. Let's try it with german AutoCAD Befehl: r3 _ROTATE3D Aktueller positiver Winkel: ANGDIR=Gegen den Uhrzeigersinn ANGBASE=0.00 Objekte wählen: nil Objekte wählen: 1 gefunden Objekte wählen: Ersten Punkt auf Achse angeben oder Achse definieren nach [Objekt/Letztes/ANsicht/X-achse/Y-achse/Z-achse/2Punkte]: *Abbruch* This is: r3 = rotate 3d select objects choose point on axis or define axis by [... X-axis/Y-axis/Z-axis ...] And this what I want to spare - just a simple rotate 3d with X-axis preselected ... and one with Y-axis preselected and one with Z-axis preselected. Should work like this: rx select objects define rotation base point objects are rotated around x-parallel through base point. It's really something very simple. I JUST want to spare the one step of entering "x" in the rotat3d command. For the lisp-pros this should be something extremely simplistic ... Quote
Lee Mac Posted January 18, 2011 Posted January 18, 2011 Ok, I'll give you a little help: (defun c:rx ( / e p a ) (if (and (setq e (car (entsel))) (setq p (getpoint "\nBase Point: ")) (setq a (getangle p "\nAngle: ")) ) (vla-Rotate3D (vlax-ename->vla-object e) (vlax-3D-point (trans p 1 0)) (vlax-3D-point (mapcar '+ (trans p 1 0) '(1. 0. 0.))) a ) ) (princ) ) That's one way to do it. Note that if you want to rotate a selection set, you wil need to iterate through it, rotating each object in turn. Also note that the above will rotate about the WCS X-Axis, not the UCS X-Axis. Lee Quote
Randolph Posted January 18, 2011 Author Posted January 18, 2011 (edited) Thanx, I'll try this. May I ask you what your reason is for preferring vla-rotate3d to rotate3d? I know how to preselect an option which appear 1st instance like: (DEFUN C:BX ()(COMMAND "_UCS" "X")) whereas (DEFUN C:RX ()(COMMAND "_ROTATE3D" "_X")) doesn't work: wrong selection, point required. So I tried to figure out how to preselect options which appear only 2nd or 3d row when working through a command. BECAUSE next thing would be mx, my, mz: MX mirror3d on YZ-parallel plane MY mirror3d on ZX-parallel plane Edited January 18, 2011 by Randolph Quote
BIGAL Posted January 19, 2011 Posted January 19, 2011 The first thing rotate3d does is asks for object to be rotated! You cant jump 2 steps ahead and then go back. Lee has posted the answer you just change the reference in (vlax-3D-point (mapcar '+ (trans p 1 0) '(1. 0. 0.))) for the y axis '(0. 1. 0.) he even called it "rx" once loaded automaticaly at start up it doesn't matter how much code is involved. You just type rx. Quote
