I cant ever get it to work... think its because I just dont know how to use it. Can anyone tell me what file this is, and where would it be located?
"AutoCAD menu utilities"
:lol: Silly rabbit....
The menu utilities loaded fine.
The error came from one of your LISP files... Open your code in the VLIDE to check, correct, and save (re-compile?).
Good luck, young pedawan.
  • Replies 30
  • jtk07
    12
  • tzframpton
    7
  • BlackBox
    5
  • irneb
    5
Found It! It was an error got it fixed but i do see this error can you explain this maybe?
in the acad2011doc.lsp i get 2 warnings
; warning: local variable used as function: SAVEVAR
Warning one goes here
(if (not (eq 'STR (type varname)))
               (princ "\nAI_SYSVAR: Bad argument type.\n")
               (savevar varname varvalue)
Warning two goes here
  ;; set a single system variable
     ((eq 'STR (type (car vars)))
        (savevar (car vars) (cdr vars))
You need to reconcile some parenthesis I think. They're not closed. I'm no Lisp programmer though so I dunno.... :oops:
:: DANGER WILL ROBBINSON :: :o
Like you've been told several times already - STAY OUT OF ACAD*####.lsp files!
Edit: Where is your CAD Manager!?
Renderman,
I understand the problems here however that was the area that the former gentleman in charge changed and had the error! I removed the error he had pasted prior but while i removed it and it showed me where his code was in it it also displayed the following. All i am trying to do is get the Acad2011***.lsp back to OEM! I have posted asking for someone to send me an original non touched Acad(OEM).lsp a few times also with no luck. I do not want to uninstall acad and reinstall it. all i am asking is this normal out of the box to have the following Warnings Posted above? I am NOT changing anything in the files. I have learned from all of you but need to get back to original to do that. :)
Please expand -
Understood. :)
Perhaps the simplest solution, is for your IT department to provide you a copy of the files you require from the disk image of your platform's installation, in lieu of asking for files from members, re-installing, etc. in this case.
IMO - This would be the *safest* (and most efficient?) solution, given your situation.
*IF* your IT department does not use disk images of various installations... then I might suggest that the entire department be replaced, and/or suggest this become a new standard operating procedure at your company - the choice is yours. :wink: lol (I'm half-kidding of course!)
Sent you a pm renderman - for everyone else i will reinstall acad to get a clean copy of the 2 acad2011 files.
You don't need to do that. Just put in the disc, and run a Repair from the Add/Remove Programs in Control Panel. :)
i was busy working on my pc lol so i used a non used station and installed it there not interfering with what i did :)
Definitely with RenderMan on that score!
As an aside, to enable you to figure out what's been changed. If you can get hold of the ACAD*####.LSP files from the original DVD (or other), then you can compare these to the modified ones. I'd use some program like Notepad++ (google for it, it's free). It's got a nifty feature to compare 2 files side-by-side, highlighting the differences. That way you can more easily figure out what should be placed in your ACAD.LSP / ACADDOC.LSP files.
Over here we have a enterprise CUI file and its accompanying MNL file. It's a lot similar to what happens in my Caddons menu. See: http://caddons.svn.sourceforge.net/viewvc/caddons/UI/
Edit: above link is wrong, use this instead:
Edited by irneb
