Drawing not Publishing [AutoCAD 2009]
Hello all,
i have a situation where some of the users have 64bit systems.
When they try to publish the drawing they can only publish a dwf file.
It should be mentioned that they have Adobe Acrobat Pro9.
My system is a 32bit with Adobe Pro8 and it works just fine and works on all other users with the same setup.
Is this a known issue with the AutoCAD 2009 and abode Pro9?
Can they use AutoCAD's default PDF printer DWGtoPDF.pc3, rather than the Adobe PDF printer? I've never heard of an issue with 64 bit and Adobe's PDF driver in AutoCAD.
