Lisp Make Layers. Lineweight 0.0 instead of "Default"
Hi all,
I'm using Mac Lee's Makalayer routine to create layers with lisp.
(defun MakeLayer ( name colour linetype lineweight willplot bitflag description )
 ;; © Lee Mac 2010
 (or (tblsearch "LAYER" name)
   (entmake
     (append
       (list
         (cons 0 "LAYER")
         (cons 100 "AcDbSymbolTableRecord")
         (cons 100 "AcDbLayerTableRecord")
         (cons 2  name)
         (cons 70 bitflag)
         (cons 290 (if willplot 1 0))
         (cons 6
           (if (and linetype (tblsearch "LTYPE" linetype))
             linetype "CONTINUOUS"
         (cons 62 (if (and colour (< 0 (abs colour) 256)) colour 7))
         (cons 370
           (fix
             (* 100
               (if (and lineweight (<= 0.0 lineweight 2.11)) lineweight 0.0)
       (if description
         (list
           (list -3
             (list "AcAecLayerStandard" (cons 1000 "") (cons 1000 description))
(defun c:norlays nil (vl-load-com)
 ;; © Lee Mac 2010
 ;; Specifications:
 ;; Description        Data Type        Remarks
 ;; Layer Name          STRING          Only standard chars allowed
 ;; Layer Colour        INTEGER         may be nil, -ve for Layer Off, Colour < 256
 ;; Layer Linetype      STRING          may be nil, If not loaded, CONTINUOUS.
 ;; Layer Lineweight    REAL            may be nil, 0 <= x <= 2.11
 ;; Plot?               BOOLEAN         T = Plot Layer, nil otherwise
 ;; Bit Flag            INTEGER         0=None, 1=Frozen, 2=Frozen in VP, 4=Locked
 ;; Description         STRING          may be nil for no description
 ;; Function will return list detailing whether layer creation is successful.
   (lambda ( lst / lts ) (setq lts (vla-get-Linetypes (vla-get-ActiveDocument (vlax-get-acad-object))))
     (mapcar 'cons (mapcar 'car lst)
       (mapcar
         (function
           (lambda ( x )
             (and (caddr x)
               (or (tblsearch "LTYPE" (caddr x))
                 (vl-catch-all-apply 'vla-load (list lts (caddr x) "acad.lin"))
             (apply 'MakeLayer x)
         lst
   ;  Name    Colour   Linetype Lineweight Plot? Bitflag      Description
   ( "EL_COMPONENTS"   7  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_CONSTR_COMP"  1  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_FITTINGS"   4  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_LABEL"   1  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_LABEL_TXT"   252  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_TERMINALS"   1  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_TERMINALS_PE"  24  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_TERMINALS_TXT"  252  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_TXT"   252  "CONTINUOUS" Default  T 0  nil  )
   ( "EL_WIRES"   252  "CONTINUOUS" Default  T 0  nil  )
   ( "GE_ANNOTATION"   7  "CONTINUOUS" Default  T 0  nil  )
   ( "GE_LABEL"   10  "CONTINUOUS" Default  T 0  nil  )
   ( "GE_LABEL_TEXT"   253  "CONTINUOUS" Default  T 0  nil  )
   ( "GE_TXT_LANGUAGE_DU"  252  "CONTINUOUS" Default  T 0  nil  )
   ( "GE_TXT_LANGUAGE_EN"  252  "CONTINUOUS" Default        T 0  nil  )
   ( "GE_TXT_LANGUAGE_FR"  252  "CONTINUOUS" Default        T 0  nil  )
   ( "GE_TXT_LANGUAGE_GE"  252  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_HEADER_FRAME"  7  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_HEADER_TXT"   7  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_MATLIST"   254  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_MATLIST_FRAME"  254  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_MATLIST_POS"  254  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_MATLIST_TXT"  252  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_TITLE_FRAME"  7  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_TITLE_LOGO"   10  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_TITLE_LOGO_TXT"  7  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_TITLE_TXT"   7  "CONTINUOUS" Default        T 0  nil  )
   ( "LA_VIEWPORTS"   230  "CONTINUOUS" Default        nil 0  nil  )
   ( "PN_ACCESSORIES"  30  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_ACTUATORS"   160  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_AIR_LINE_EQUIPMENT"  40  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_BRACKET_MOUNTING"  1  "ACAD_ISO12W100"Default        T 0  nil  )
   ( "PN_CABINET"   8  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_CABINET_DIM"  8  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_COMPONENTS"   7  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_CONDUCTS"   3  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_CONSTR_COMP"  2  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_DRAIN"   3  "HIDDEN" Default        T 0  nil  )
   ( "PN_EXHAUST"   104  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_FITTINGS"   30  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_IDENTIFICATION"  4  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_PILOT_SUPPLY"  3  "HIDDEN" Default        T 0  nil  )
   ( "PN_PORT_NUMBERS"  8  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_PRESSURE_SWITCHES"  200  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_PROPORTIONAL_VALVES" 226  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_SECTIONS"   3  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_SUB-BASES"   8  "ACAD_ISO12W100"Default        T 0  nil  )
   ( "PN_SUB-BASE_CONDUCTS"  2  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_SUPPLY"   3  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_TXT"   3  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_VACUUM"   60  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_VALVES"   240  "CONTINUOUS" Default        T 0  nil  )
   ( "PN_VALVES_OVERRIDE"  1  "CONTINUOUS" Default        T 0  nil  )
When running the program i'm getting following error:
Command: (load "nor_layers")
C:NORLAYS
Command: norlays
; error: bad argument type for compare: 0.0 DEFAULT
Command:
When using "nil" instead of "Default" for the lineweight, i get "0.0" lines.
Are these the same as "Default" or is there another parameter to use to get "Default" lineweights?
thx
  • Replies 22
  • Lee Mac
    8
  • Sittingbull
    8
  • stevesfr
    2
  • rhino
    2
It's okay :oops:. Found it.
Default Lineweight
Sets the current default lineweight. Lineweight values consist of fixed settings, including BYLAYER, BYBLOCK, and DEFAULT. Values are calculated in either inches or millimeters; millimeters are the default. If you enter a valid lineweight value, the current default lineweight is set to the new value. If you enter any other value, the default is set to the nearest valid value.
To plot an object with a lineweight that is not found in the list of fixed lineweight values, you can use the Plot Style Table Editor to customize plotted lineweights. See Control Plotted Lineweight and Linetype in the User's Guide. The DEFAULT value is set by the LWDEFAULT system variable and has an initial value of 0.01 inches or 0.25 mm. The lineweight value of 0 plots at the thinnest lineweight available on the specified plotting device and is displayed at a value of one pixel in model space.
Hi SittingBull,
I have updated the code, please read the specifications panel regarding lineweight:
 ;; © Lee Mac 2010
   (entmake
     (append
       (list
         (cons 0 "LAYER")
         (cons 2  name)
         (cons 70 bitflag)
         (cons 6
         (cons 370
           (if (minusp lineweight) -3
             (fix
               (* 100
       (if description
         (list
           (list -3
 ;; © Lee Mac 2010
 ;; Specifications:
 ;; Layer Lineweight    REAL            may be nil, negative=Default, otherwise 0 <= x <= 2.11
       (mapcar
         (function
           (lambda ( x )
             (and (caddr x)
         lst
   ( "EL_COMPONENTS"            7  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_CONSTR_COMP"           1  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_FITTINGS"              4  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_LABEL"                 1  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_LABEL_TXT"           252  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_TERMINALS"             1  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_TERMINALS_PE"         24  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_TERMINALS_TXT"       252  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_TXT"                 252  "CONTINUOUS"     -3       T      0      nil  )
   ( "EL_WIRES"               252  "CONTINUOUS"     -3       T      0      nil  )
   ( "GE_ANNOTATION"            7  "CONTINUOUS"     -3       T      0      nil  )
   ( "GE_LABEL"                10  "CONTINUOUS"     -3       T      0      nil  )
   ( "GE_LABEL_TEXT"          253  "CONTINUOUS"     -3       T      0      nil  )
   ( "GE_TXT_LANGUAGE_DU"     252  "CONTINUOUS"     -3       T      0      nil  )
   ( "GE_TXT_LANGUAGE_EN"     252  "CONTINUOUS"     -3       T      0      nil  )
   ( "GE_TXT_LANGUAGE_FR"     252  "CONTINUOUS"     -3       T      0      nil  )
   ( "GE_TXT_LANGUAGE_GE"     252  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_HEADER_FRAME"          7  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_HEADER_TXT"            7  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_MATLIST"             254  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_MATLIST_FRAME"       254  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_MATLIST_POS"         254  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_MATLIST_TXT"         252  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_TITLE_FRAME"           7  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_TITLE_LOGO"           10  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_TITLE_LOGO_TXT"        7  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_TITLE_TXT"             7  "CONTINUOUS"     -3       T      0      nil  )
   ( "LA_VIEWPORTS"           230  "CONTINUOUS"     -3      nil     0      nil  )
   ( "PN_ACCESSORIES"          30  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_ACTUATORS"           160  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_AIR_LINE_EQUIPMENT"   40  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_BRACKET_MOUNTING"      1  "ACAD_ISO12W100" -3       T      0      nil  )
   ( "PN_CABINET"               8  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_CABINET_DIM"           8  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_COMPONENTS"            7  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_CONDUCTS"              3  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_CONSTR_COMP"           2  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_DRAIN"                 3  "HIDDEN"         -3       T      0      nil  )
   ( "PN_EXHAUST"             104  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_FITTINGS"             30  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_IDENTIFICATION"        4  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_PILOT_SUPPLY"          3  "HIDDEN"         -3       T      0      nil  )
   ( "PN_PORT_NUMBERS"          8  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_PRESSURE_SWITCHES"   200  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_PROPORTIONAL_VALVES" 226  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_SECTIONS"              3  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_SUB-BASES"             8  "ACAD_ISO12W100" -3       T      0      nil  )
   ( "PN_SUB-BASE_CONDUCTS"     2  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_SUPPLY"                3  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_TXT"                   3  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_VACUUM"               60  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_VALVES"              240  "CONTINUOUS"     -3       T      0      nil  )
   ( "PN_VALVES_OVERRIDE"       1  "CONTINUOUS"     -3       T      0      nil  )
:thumbsup: thx a lot Lee.
You're welcome SittingBull, I hadn't accounted for Default lineweight in the previous code.. :oops:
this would work too:
(setq lay_tbl  (vla-get-layers (vla-get-activedocument (vlax-get-acad-object))))
 (vlax-for n lay_tbl  (vla-put-LineWeight n 0))
for loading the linetypes:
;Line Load Module
(defun ln_load (/ linelist lin)
 (setq linelist '(("Center" . "acadiso.lin")
                  [code]
("Hidden" . "acadiso.lin"))
(foreach lin linelist
(or (tblsearch "LTYPE" (car lin))
(command "._-linetype" "_Load" (car lin) (cdr lin) "")
); end ln_load function[/code]
  • 2 weeks later...
Hi all,
The code worked fine untill i started using layers starting with ISO.
Dunno why, but when running the lisp on some files, it only creates the linetypes and not the layers.
Iff i make just one layer, average name, doen't matter, the lisp works again.
I've added a file wich is a copy of the acadiso.dwt template.
Here's the code with the layers i use:
 ;; © Lee Mac 2010
   (entmake
     (append
       (list
         (cons 0 "LAYER")
         (cons 2  name)
         (cons 70 bitflag)
         (cons 6
         (cons 370
             (fix
               (* 100
       (if description
         (list
           (list -3
(defun c:isolays nil (vl-load-com)
 ;; © Lee Mac 2010
 ;; Specifications:
       (mapcar
         (function
           (lambda ( x )
             (and (caddr x)
         lst
   ( "ISO_LIN_UNI"       50  "CONTINUOUS"     0.20     T      0      "UNIversal line for a symbol"               )
   ( "ISO_LIN_FLU"       70  "CONTINUOUS"     0.20     T      0      "Elements through which a FLUid flows"      )
   ( "ISO_LIN_HAT"               9  "CONTINUOUS"     0.20     T      0      "Cross-HATching"                            )
   ( "ISO_LIN_ASS"        6  "ACAD_ISO10W100" 0.20     T      0      "ASSembly line"                             )
   ( "ISO_TEX_IDE"       70  "CONTINUOUS"     0.25     T      0      "Text for IDEntification of ports"          )
   ( "ISO_TEX_POS"        4  "CONTINUOUS"     0.25     T      0      "POSition number"                           )
   ( "ISO_TEX_DES"       50  "CONTINUOUS"     0.25     T      0      "Text for DEScription (12, 14, 89)"         )
   ( "ISO_LIN_PRE"       30  "CONTINUOUS"     0.20     T      0      "PREssure line"                             )
   ( "ISO_LIN_RES"      140  "CONTINUOUS"     0.20     T      0      "REServoir line"                            )
   ( "ISO_LIN_CON"       30  "ACAD_ISO02W100" 0.20     T      0      "CONtrole line"                             )
   ( "ISO_LIN_DRA"      140  "ACAD_ISO02W100" 0.20     T      0      "DRAin line"                                )
   ( "ISO_LIN_WOR"       70  "CONTINUOUS"     0.20     T      0      "WORking line"                              )
   ( "ISO_TEX_DES_025"       70  "CONTINUOUS"     0.25     T      0      "Text for DEScription 2.5MM"                )
   ( "ISO_TEX_DES_035"       30  "CONTINUOUS"     0.35     T      0      "Text for DEScription 3.5MM"                )
   ( "ISO_TEX_DES_050"       50  "CONTINUOUS"     0.50     T      0      "Text for DEScription 5.0MM"                )
   ( "ISO_TEX_DUT"               8  "CONTINUOUS"     -3       T      0      "Dutch text"                                )
   ( "ISO_TEX_ENG"               8  "CONTINUOUS"     -3       T      0      "English text"                              )
   ( "ISO_TEX_FRE"               8  "CONTINUOUS"     -3       T      0      "French text"                               )
   ( "ISO_TEX_GER"               8  "CONTINUOUS"     -3       T      0      "German text"                               )
   ( "ISO_LIN_DIM"               8  "CONTINUOUS"     -3       T      0      "Dimensions"                                )
   ( "ISO_LIN_SHE"               9  "CONTINUOUS"     -3       T      0      "Layout sheet frame"                        )
   ( "ISO_TEX_SHE"               9  "CONTINUOUS"     -3       T      0      "Layout sheet text"                         )
   ( "ISO_LIN_MAT_LIS"           9  "CONTINUOUS"     -3       T      0      "Layout material list"                      )
   ( "ISO_LIN_MAT_FRA"           8  "CONTINUOUS"     -3       T      0      "Layout material list frame"                )
   ( "ISO_LIN_MAT_POS"           7  "CONTINUOUS"     -3       T      0      "Layout material list position"             )
   ( "ISO_TEX_MAT"               7  "CONTINUOUS"     -3       T      0      "Layout material list text"                 )
   ( "ISO_LIN_TIT"               7  "CONTINUOUS"     -3       T      0      "Layout titleblock frame"                   )
   ( "ISO_LIN_LOG"              10  "CONTINUOUS"     -3       T      0      "Logo"                                      )
   ( "ISO_TEX_LOG"               7  "CONTINUOUS"     -3       T      0      "Layout titleblock logo text"               )
   ( "ISO_TEX_TIT"               7  "CONTINUOUS"     -3       T      0      "Layout titleblock text"                    )
   ( "ISO_LIN_VIE"             230  "CONTINUOUS"     -3      nil     0      "Layout viewports"                          )
   ( "ISO_LIN_ACT"             160  "CONTINUOUS"     -3       T      0      "Pneumatic actuators"                       )
   ( "ISO_LIN_VAC"              60  "CONTINUOUS"     -3       T      0      "Vacuum"                                    )
   ( "ISO_LIN_ALE"               2  "CONTINUOUS"     -3       T      0      "Pneumatic Air Line Equipment"              )
   ( "ISO_LIN_PRE_SWI"         200  "CONTINUOUS"     -3       T      0      "Pneumatic pressure switches"               )
   ( "ISO_LIN_PRO_VAL"         226  "CONTINUOUS"     -3       T      0      "Pneumatic proportional valves"             )
   ( "ISO_LIN_VAL"             240  "CONTINUOUS"     -3       T      0      "Pneumatic valves"                          )
   ( "ISO_LIN_SUB"               8  "CONTINUOUS"     -3       T      0      "Pneumatic sub-bases"                       )
   ( "ISO_LIN_ACC"              30  "CONTINUOUS"     -3       T      0      "Pneumatic accessories"                     )
   ( "ISO_LIN_CAB"               8  "CONTINUOUS"     -3       T      0      "Pneumatic cabinet"                         )
   ( "ISO_LIN_COM"               7  "CONTINUOUS"     -3       T      0      "Pneumatic components"                      )
   ( "ISO_LIN_SEC"               3  "CONTINUOUS"     -3       T      0      "Pneumatic conduct sections"                )
   ( "ISO_LIN_EXH"             104  "CONTINUOUS"     -3       T      0      "Pneumatic exhaust"                         )
   ( "ISO_LIN_OVE"               1  "CONTINUOUS"     -3       T      0      "Pneumatic override"                        )
   ( "ISO_LIN_PIL"               1  "CONTINUOUS"     -3       T      0      "Pneumatic pilot"                           )
   ( "ISO_LIN_RET_SPR"           1  "CONTINUOUS"     -3       T      0      "Pneumatic return spring"                   )
   ( "ISO_LIN_ELE_COM"           1  "CONTINUOUS"     -3       T      0      "Electric components"                       )
   ( "ISO_LIN_ELE_WIR"           8  "CONTINUOUS"     -3       T      0      "Electric wires"                            )
   ( "ISO_LIN_LAB"              10  "CONTINUOUS"     -3       T      0      "Labels"                                    )
acadiso.dwg
SB
       (mapcar
         (function
           (lambda ( x )
             (and (caddr x)
                 (vl-catch-all-apply 'vla-load (list lts (caddr x) "[color=red]acadiso.lin[/color]"))
         lst
the line definition file should be correctly referenced in the code.
don't use the "description"- there be a bug there :twisted:
Ah...
Damn...
Thanks for the tip m8:thumbsup:.
Indeed, cutting out the description does the trick. Too bad :(.
  • 2 weeks later...
I think i didn' t get how to trigger the thing.
On (load"makelayers"), nothing happens.
Command: (load"makelayers")
LM:STR->LST
So i tried, LM:STR->LST, LM, STR->LST,... no reaction i can see...
LM:str->lst is just a subfunction, use 'MakeLayers' (defined at the top) - I should've added a loading message.
You might like this novelty program:
http://lee-mac.com/getsyntax.html
Works fine for new drawings on 2011.
But not with older drawings (2004 i think)
[ATTACH]26294[/ATTACH]
Some layers with description:
isolays.lsp
Lee, in the getsyntax.lsp program, how can one define a unique search directory instead of the default which, in my case, is C:\users\something\documents ?
in other words, can it be set or hard coded to whatever the user wishes? which should be the directory where all the lisps are kept ?
thx, Steve
The Description will only work with drawings that support Layer Descriptions
thx, Steve
Hi Steve,
You can hard-code a directory here [Line 28] (Currently an empty string):
(getfiled "Select LISP File to Query" "[color=red][b]C:\\MyFolder\\MyDirectory[/b][/color]" "lsp" 16)
Lee
Hi Steve,
Lee
I understand !!! now I know what those two "" were for in the original program, they forced the default location. Thank you ! !
Steve
Steve
Excellent :)
If you're interested, the details of getfiled [GetFileD(ialog)] are in the VLIDE Help documentation.
Lee
