TiffF Posted January 18, 2011 Posted January 18, 2011 I have just upgraded to Civil 3d 2011. I am trying to make a new template and I brought in an old rawing to do so. Currently I am trying to delete all the layers on the manager except 0. They all seem to show they have objects in that layer even though I have purged all items and zoomed out deleteing everything multiple times. I checked the xreferenced items and I have none shown. Is there anything else I can do? Thanks a lot for any help. Quote
designerstuart Posted January 18, 2011 Posted January 18, 2011 so the drawing has no entities in it at all? how many of these layers are there? i think some layers are related to styles and 'other' things than linework etc. defpoints, like layer0, cannot be deleted. Quote
lpseifert Posted January 18, 2011 Posted January 18, 2011 If the layers are part of one of Civil 3D's styles they won't delete/purge. Quote
TiffF Posted January 18, 2011 Author Posted January 18, 2011 COrrest no entities at all. 87 layers. Quote
TiffF Posted January 18, 2011 Author Posted January 18, 2011 Could 87 layers be part of the styles? How do I check that? Laydel didn't help either. Quote
CyberAngel Posted January 18, 2011 Posted January 18, 2011 The only other references I know about in Civil 3D are for default object creation. Go to Toolspace, Settings tab, right-click on drawing name, select Drawing Settings, and select Object Layers tab. If any of those layers are not 0, and you don't want object types to go on layers other than 0, then set them to 0. As for styles, typically you want to look at the Display tab. Every object in, say, a profile view can go on a specific layer. They default to 0, but if you're working with an existing drawing there's no telling. Your best bet, if you can't find those 87 layers, may be to start from scratch. That way you get the default settings. If you've developed styles you want to keep, you can drag them from the old drawing into the new one. Quote
BlackBox Posted January 18, 2011 Posted January 18, 2011 Perhaps there are some block references that still reside within the drawing? *IF* so, do a PURGE, and select 'Purge All' - Be sure to have the 'Purge nested items' box checked. Hope this helps! Quote
JPlanera Posted January 18, 2011 Posted January 18, 2011 I love your signature JPlanera thank you! Quote
TiffF Posted January 18, 2011 Author Posted January 18, 2011 I tried purge and it didn't work. I didn't know about the Drawing Settings, but that still didn't work. Odd... Maybe since I brought the layers in from an old drawing when making the template? Quote
JPlanera Posted January 18, 2011 Posted January 18, 2011 LAYDEL will delete the layer no matter what state it is in.... can you post a drawing with all the layers?? Quote
TiffF Posted January 18, 2011 Author Posted January 18, 2011 I rebooted my pc and cad and was able to use laydel again. That is working. Thanks a lot . Quote
BIGAL Posted January 19, 2011 Posted January 19, 2011 Go to toolspace, settings, click on say surface, surface styles, you can now see what surface styles are in the drawing and what layers are to be assigned for objects even if you have not done anything. You will find your undeletable layers there (new word undeletable) we start with around 500 layers (all surveys codes to layers) a purge etc = 100 layers Quote
JPlanera Posted January 19, 2011 Posted January 19, 2011 EEE Gads, man! Thats a lot of undeletables... Quote
