60ftjunkie Posted January 19, 2011 Posted January 19, 2011 Hi all. New here, just learning a bit about AutoCad and have a question which I hope has a relatively simple answer. I found a LISP routine to draw a helix possibly from around 2002, named and referred to simply as helix.lsp. It does a satisfactory job enabling me to specify a top and base radius, height, number of turns and number of segments per turn. If I center a circle on one endpoint of the helix and extrude it using the helix as a path, all is well, basically makes what may to some look like a coil spring. Issue is when I do the exact same with a square or hex, etc. Result is that the object is not only extruded along the path, but is also "spun" as it is extruded. I feel that the same is true with the circle, however it's simply not detectable since it is a circle. What oversight on my part has been made and/or what may be necessary to counteract this? AutoCad 2005 under WinXP MCE BTW, I am in early stages of learning this stuff, so you guys don't flame me out too badly. Thanks, Dave Quote
fuccaro Posted January 19, 2011 Posted January 19, 2011 (edited) Hello DAve! With AutoCAD 2005 you are limited. In newer versions modern commands were added to solve this problem and these days people will use Loft instead of Extrude. In the old days I wrote Lisp routines (are posted in this forum), but using them alot I ended up with huge file sizes. Maybe a walk-around for you could be to use surfaces instead of solids. ***** editing ***** I searched for these old threads: http://www.cadtutor.net/forum/showthread.php?78-Get-your-Helix-here! http://www.cadtutor.net/forum/showthread.php?221-TWISTING-3D-OBJECTS-WITH-AUTOCADR14 Edited January 19, 2011 by fuccaro adding links Quote
JD Mather Posted January 19, 2011 Posted January 19, 2011 BTW, I am in early stages of learning this stuff.... If you are a student you can get AutoCAD 2011 or Inventor 2011 for free and get more control over this (Sweep). http://www.autodesk.com/edcommunity Quote
60ftjunkie Posted January 20, 2011 Author Posted January 20, 2011 Thanks fuccaro! helsurf suffices fine for my simple purposes. Thanks for the tip JD, unfortunately I'm not currently a student. I appreciate the help fellas, I'm sure I'll be back! Dave Quote
fuccaro Posted January 20, 2011 Posted January 20, 2011 Ok, Dave, we are happy to help you. Stay around here and you will see how great this site is. Maybe you can also help others Quote
