justAnIntern Posted January 20, 2011 Posted January 20, 2011 I'm working in Civil 3d 2010. how can i get the menu bar to appear for surface, alignment, corridors, etc? Quote
JPlanera Posted January 20, 2011 Posted January 20, 2011 I dont have Civil, but if its a standard menubar, then set MENUBAR to 1 at the command line Quote
justAnIntern Posted January 20, 2011 Author Posted January 20, 2011 thanks. i did that but no luck Quote
JPlanera Posted January 20, 2011 Posted January 20, 2011 Could these be toolbars?? Try a right click on any toolbar to see a list... Quote
justAnIntern Posted January 20, 2011 Author Posted January 20, 2011 I have attched a screenshot of the interface. scree-shot.docx Quote
BlackBox Posted January 20, 2011 Posted January 20, 2011 I'm working in Civil 3d 2010. how can i get the menu bar to appear for surface, alignment, corridors, etc? From the CUI EDITOR (._cui commmand), select your workspace in the Customizations in all Files pane Click the Customize Workspace button in the Workspace Contents pane Back in the Customizations in all Files pane, navigate to the Menus node of the CIVIL CUI, and check the boxes to the left of Surfaces, Alignments, and Corridors Click the Done button from the Workspace Contents pane Apply your changes, and click OK to return to your drawing Quote
BlackBox Posted January 20, 2011 Posted January 20, 2011 I have attched a screenshot of the interface. Please re-post your screen shot in image file format (.jpg, .png, etc.); simple MS Paint can handle this (Print Screen, Ctrl+V). Quote
justAnIntern Posted January 20, 2011 Author Posted January 20, 2011 your previous post helped out. thank you! Quote
BlackBox Posted January 20, 2011 Posted January 20, 2011 your previous post helped out. thank you! Your welcome. Quote
