Preciosu21 Posted January 20, 2011 Posted January 20, 2011 I have just imported a field book into Civil 3D 2010. I have tried several times to unlock these points I just imported. I have deleted the file and reimported it to see if this helps and for some reason the points will not unlock. This wouldn't normally be a problem but I need to move the points within my drawing and for this to happen they must be unlocked. Please help Quote
sinc Posted January 21, 2011 Posted January 21, 2011 Did you unlock them in the Survey database (Toolspace -> Survey tab)? Quote
Preciosu21 Posted January 25, 2011 Author Posted January 25, 2011 Yes, I have unlocked them everwhere the option is available, still locked Quote
BlackBox Posted January 25, 2011 Posted January 25, 2011 I have just imported a field book ... I need to move the points Please forgive my curiousity... Why would one need to move survey points? Did they (the points) come in with a different coordinate system (i.e. NAD*, ETRF*, etc.)? Quote
sinc Posted January 26, 2011 Posted January 26, 2011 If you did "Unlock in drawing" from the Survey Database, then the only other thing I can think of is that the layer is locked. Quote
