vnsharifi Posted January 21, 2011 Posted January 21, 2011 Hello there. I found below lisp in internet. What is does is , It will find the bounding box of selected object and it put those data in minpoint and maxpoint variable and show them in command prompt. with this format ( x1 y1 z1 , x2 y2 z2) I believe , right term is " Buffer ". Now my question is , how can I can read X,Y coordinates of those point in vb net. Or at least write them in a file. I nice example would be helpful because I am not a pro. Thanks for all help. ;;============================= (defun C:minmax() (setq BarEname (cdr (car (entget (car (entsel "\nselect your object ")))))) (ucs-bbox BarEname) ) ;; can be used with vla-transformby to ;; transform objects from the UCS to the WCS (defun UCS2WCSMatrix () (vlax-tmatrix (append (mapcar '(lambda (vector origin) (append (trans vector 1 0 t) (list origin)) ) (list '(1 0 0) '(0 1 0) '(0 0 1)) (trans '(0 0 0) 0 1) ) (list '(0 0 0 1)) ) ) ) ;; transform objects from the WCS to the UCS (defun WCS2UCSMatrix () (vlax-tmatrix (append (mapcar '(lambda (vector origin)(append (trans vector 0 1 t) (list origin))) (list '(1 0 0) '(0 1 0) '(0 0 1)) (trans '(0 0 0) 1 0) ) (list '(0 0 0 1)) ) ) ) ;; Returns the UCS coordinates of the object bounding box about UCS ;; Argument ;; obj : a graphical object (ename or vla-object) ;; Return ;; a list of left lower point and right upper point UCS coordinates (defun ucs-bbox (obj / minpoint maxpoint) (vl-load-com) (and (= (type obj) 'ENAME) (setq obj (vlax-ename->vla-object obj)) ) (vla-TransformBy obj (UCS2WCSMatrix)) (vla-getboundingbox obj 'minpoint 'maxpoint) (vla-TransformBy obj (WCS2UCSMatrix)) (list (vlax-safearray->list minpoint) (vlax-safearray->list maxpoint) ) ) Quote
fixo Posted January 21, 2011 Posted January 21, 2011 (edited) Here you go [color=#008000]'[/color] [color=#008000]' Created by SharpDevelop.[/color] [color=#008000]' User: Олег[/color] [color=#008000]' Date: 21.01.2011[/color] [color=#008000]' Time: 11:46[/color] [color=#008000]' [/color] [color=#008000]' To change this template use Tools | Options | Coding | Edit Standard Headers.[/color] [color=#008000]'[/color] [color=#0000ff]Imports[/color] System [color=#0000ff]Imports[/color] System.[color=#0000ff]Text[/color] [color=#0000ff]Imports[/color] System.Data [color=#0000ff]Imports[/color] System.IO [color=#0000ff]Imports[/color] System.Globalization [color=#0000ff]Imports[/color] System.Collections [color=#0000ff]Imports[/color] System.Runtime.InteropServices [color=#0000ff]Imports[/color] System.Reflection [color=#0000ff]Imports[/color] Autodesk.AutoCAD.Runtime [color=#0000ff]Imports[/color] Autodesk.AutoCAD.Geometry [color=#0000ff]Imports[/color] Autodesk.AutoCAD.EditorInput [color=#0000ff]Imports[/color] Autodesk.AutoCAD.DatabaseServices [color=#0000ff]Imports[/color] Autodesk.AutoCAD.ApplicationServices <Assembly: CommandClass([color=#0000ff]GetType[/color](TextCommands.ImportPoints))> [color=#0000ff]Namespace[/color] TextCommands [color=#0000ff]Public[/color] [color=#0000ff]Class[/color] ImportPoints <CommandMethod("CSV")> _ [color=#0000ff]Public[/color] [color=#0000ff]Shared[/color] [color=#0000ff]Sub[/color] ImbortBounds() [color=#0000ff]Dim[/color] fname [color=#0000ff]As[/color] [color=#6f002f]String[/color]="C:\usedFiles\bbox.csv" [color=#0000ff]Dim[/color] oldcult [color=#0000ff]As[/color] CultureInfo= Threading.Thread.CurrentThread.CurrentCulture Threading.Thread.CurrentThread.CurrentCulture= [color=#8515ea]New[/color] CultureInfo("EN-us") [color=#0000ff]Dim[/color] db [color=#0000ff]As[/color] Database=HostApplicationServices.WorkingDatabase [color=#0000ff]Dim[/color] doc [color=#0000ff]As[/color] Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument [color=#0000ff]Dim[/color] ed [color=#0000ff]As[/color] Editor=doc.Editor [color=#0000ff]Dim[/color] mtx [color=#0000ff]As[/color] Matrix3d= ed.CurrentUserCoordinateSystem [color=#0000ff]Dim[/color] pts [color=#0000ff]As[/color] List([color=#0000ff]Of[/color] [color=#6f002f]String[/color])= [color=#8515ea]New[/color] List([color=#0000ff]Of[/color] [color=#6f002f]String[/color]) [color=#0000ff]Dim[/color] psr [color=#0000ff]As[/color] PromptSelectionResult =ed.GetSelection() [color=#0000ff]If[/color] psr.Status <> PromptStatus.OK [color=#0000ff]Then[/color] ed.WriteMessage("{0}Selection Returned: {0}" ,vbCr,psr.Status) [color=#0000ff]Return[/color] [color=#0000ff]End[/color] [color=#0000ff]If[/color] [color=#0000ff]Dim[/color] sset [color=#0000ff]As[/color] SelectionSet = psr.Value ed.WriteMessage("{0}Selection Returned: {0}" ,vbCr,sset.Count) [color=#0000ff]If[/color] sset.Count=0 [color=#0000ff]Then[/color] ed.WriteMessage("{0}Nothing Selected, exit...",vbcr) [color=#0000ff]return[/color] [color=#0000ff]End[/color] [color=#0000ff]If[/color] pts.Add([color=#6f002f]String[/color].Format("{0}{6}{1}{6}{2}{6}{3}{6}{4}{6}{5}{7}", _ "Min X","Min Y","Min Z","Max X","Max Y","Max Z",vbtab,vbclf)) [color=#0000ff]Using[/color] tr [color=#0000ff]As[/color] Transaction=db.TransactionManager.StartTransaction() [color=#0000ff]Try[/color] [color=#0000ff]For[/color] [color=#0000ff]Each[/color] ent [color=#0000ff]As[/color] SelectedObject [color=#0000ff]In[/color] sset [color=#0000ff]Dim[/color] id [color=#0000ff]As[/color] ObjectId = ent.ObjectId [color=#0000ff]Dim[/color] obj [color=#0000ff]As[/color] Entity = [color=#0000ff]TryCast[/color](tr.GetObject(id, OpenMode.ForRead), Entity) [color=#0000ff]If[/color] ([color=#8515ea]Not[/color] ent [color=#8515ea]Is[/color] [color=#0000ff]Nothing[/color]) [color=#0000ff]Then[/color] [color=#0000ff]Dim[/color] ex3d [color=#0000ff]As[/color] Extents3d=obj.GeometricExtents [color=#0000ff]Dim[/color] pd [color=#0000ff]As[/color] Point3d=ex3d.MinPoint.TransformBy(mtx) [color=#0000ff]Dim[/color] pu [color=#0000ff]As[/color] Point3d=ex3d.MaxPoint.TransformBy(mtx) [color=#0000ff]Dim[/color] strtmp [color=#0000ff]As[/color] [color=#6f002f]String[/color]= _ [color=#6f002f]String[/color].Format("{0:f3}{6}{1:f3}{6}{2:f3}{6}{3:f3}{6}{4:f3}{6}{5:f3}{7}", _ pd.X,pd.Y,pd.Z,pu.X,pu.Y,pu.Z,vbtab,vbclf) pts.Add(strtmp) [color=#0000ff]End[/color] [color=#0000ff]if[/color] [color=#0000ff]Next[/color] [color=#0000ff]If[/color] pts.Count>1 [color=#0000ff]Then[/color] [color=#0000ff]Try[/color] [color=#0000ff]Using[/color] sw [color=#0000ff]As[/color] [color=#8515ea]New[/color] StreamWriter(fname) [color=#0000ff]For[/color] [color=#0000ff]Each[/color] coords [color=#0000ff]As[/color] [color=#6f002f]String[/color] [color=#0000ff]In[/color] pts sw.WriteLine(coords) [color=#0000ff]Next[/color] sw.Close() [color=#0000ff]End[/color] [color=#0000ff]Using[/color] [color=#0000ff]Catch[/color] ex [color=#0000ff]As[/color] IOException ed.WriteMessage("{0}Error while processing the file.",vbCr) [color=#0000ff]Catch[/color] ex [color=#0000ff]As[/color] System.Exception ed.WriteMessage("{0}Error reading in file data.",vbCr) [color=#0000ff]End[/color] [color=#0000ff]Try[/color] [color=#0000ff]End[/color] [color=#0000ff]If[/color] [color=#0000ff]Catch[/color] ex [color=#0000ff]As[/color] System.Exception ed.WriteMessage("{0}{1}",vbCr,ex.ToString) [color=#0000ff]Finally[/color] Threading.Thread.CurrentThread.CurrentCulture=oldcult [color=#0000ff]End[/color] [color=#0000ff]Try[/color] [color=#0000ff]End[/color] [color=#0000ff]using[/color] [color=#0000ff]End[/color] [color=#0000ff]Sub[/color] [color=#0000ff]End[/color] [color=#0000ff]Class[/color] [color=#0000ff]End[/color] [color=#0000ff]Namespace[/color] ~'J'~ Edited January 21, 2011 by fixo tags missed Quote
