Is it possible to install two different cad version side by side?
Hi guys,
I was wondering if it's possible to install AutoCad 2011 or any older releases on the same PC with an already CAD installation.
I mean, with no issues at all
Buy and thanks,
Stefano
all signs point to YES...
but you will have issues, no matter what... multiple installs or not... such is life..
do you "need" to have all those versions on your computer??? Just asking
Edited by JPlanera
asking a question...
Hi JPlanera and thanks for your reply answer
but you will have issues...
which ones...?
Find me a computer, or computer software that does not have issues at one point in time, and i will take it back... I simply meant that as a generalization
oh...I see what you mean :lol:
Could you please tell me if the 2011 release is so much different to use and understand than the older 2005 one?
For an amateur user like me, of course
According to AutoDesk the only users who have their permission to do this are the ones on Subscription. Anyone else is supposed to remove the older version after 30 days has passed.
Now, is AutoDesk going to actively search out everyone who owns AutoCAD to see that they have followed the rules? Probably not.
At one time, prior to going on Subscription, I had r9, r12, 2000 and 2004 all on the same computer. Why? Because I never bothered to remove them. Did I have an "issues"? Only one. Sometimes all my dwg files would become "associated" with an older version rather than the most current version I was using. Otherwise, every one of the versions worked as normally expected.
There will be a big difference between 2005 and 2011 as you will eventually see. First and foremost is the "Ribbon".
Hi ReMark and many thanks for your quick and clear reply answer 8) as you usually do!
what's that's...?
The "Ribbon" is really a Microsoft Office ripoff that doesn't work anywhere near as efficiently as AutoDesk would have you to believe. You'll end up wasting a lot of time clicking on tabs and panels and buttons. Some users hate it so much they have turned it off altogether and replaced it with Toolbars.
@RenderMan
thanks for the link you posted to me
@ReMark
thanks for your easy explanation
@RenderMan
@ReMark
That's what we try to do here.
You're entirely welcomed. :)
Install 2011 and play around with the ribbon, you might like it. When, like most of us, you decide you've had enough of that nonsense, there's a button in the lower righthand corner that's called "workspace switching". Clicking the arrow will pull up an assortment of options. Clicking on "AutoCAD Classic" will allow you to actually get some work done the way you're accustomed to doing it (with some customization, of course).
I do use the Ribbon but it is a customized version.
