lubracali Posted January 22, 2011 Posted January 22, 2011 I was wondering if there is a way to make an array variable with an integer in is name. When I indicate a point in autocad/vba I have to use an array. Dim pt1(0 To 2) As Double pt1(0) = x pt1(1) = y pt1(2) = z If I want to write a loop for...next, according to a set of values contained in some textboxes and put into another array, I can not change to the index of the point (pt1, 1 is the index). Let me explain. If I want to draw circles whose centers x coordinate are placed in 3 textboxes, I can draw them one at a time or can I try to write a for loop next. Dim txt(1 To 3) As Double txt(1) = TextBox1.Text txt(2) = textbox2.Text txt(3) = textbox3.Text Dim pt1(0 To 2) As Double Dim pt2(0 To 2) As Double Dim pt3(0 To 2) As Double Dim K As Integer Dim circ(1 To 3) As AcadCircle For K = 1 To 3 ptK(0) = txt(K) ptK(1) = 100 Set circ(K) = ThisDrawing.ModelSpace.AddCircle(ptK, 6) Next K The problem is that VBA does not recognize ptK as a depending of the index K. Quote
SEANT Posted January 22, 2011 Posted January 22, 2011 Variable names can not be processed in that way. I may not grasp the full scope of the problem but it seems like this produces the desired result. Dim Pt(2) as Double Dim circ(2) As AcadCircle Dim i as Integer For i = 0 to 2 Pt(0) = txt(i + 1) Pt(1) = 100 Pt(2) = 0 Set circ(i) = ThisDrawing.ModelSpace.AddCircle(Pt, 6) Next Quote
