themoffster Posted January 22, 2011 Posted January 22, 2011 I'm just working on the basics to learn the ins and outs of autocad architecture 10. As such, I have created a simple square house with a roof that has walls 20' high. I have changed the floor levels via the ctrl+5 tool (so that the upper floor starts from 10'), but how do i change the floor that i am working on? I've got the shell of the building setup and have put in some inner walls on the ground floor, but want to select the upper floor and do the layout of that - but i can't see an option to do so. Could someone tell me how to change the floor level that i am working on? Cheers! Quote
BIGAL Posted January 24, 2011 Posted January 24, 2011 Couple of ways draw all floors at zero then copy and move to make a 3d model its just a bit easier to make each one seperately, you can use elev to set an elevation that you are drawing on. Quote
