rvignacio Posted January 23, 2011 Posted January 23, 2011 Hello All, Is there anybody there who can help me solving this problem below. Everytime I open Autocad the message below appears, it affected the default settings on Autocad ie. Fill; highlight; mbuttonpan and many more, if I change back the settings manually it's fine, but everytime I open another session it goes back to same problem. I've tried to remove and re-install my software, but problem still the occurs. Please assist. Thanks Rhandy ---------------------------------------------------------------------------------------------------- Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: VAULT Regenerating model. Initializing.........Done. C:\Program Files\AutoCAD Civil 3D 2009\Civil\AeccUiModel.arx is an invalid ARX file. AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc. ; error: bad character read (octal): 0 AutoCAD menu utilities loaded.; error: bad character read (octal): 0 *Cancel* A drawing with this name already exists. Do you want to replace it? Command: COMMANDLINE ---------------------------------------------------------------------------------------- Quote
BlackBox Posted February 1, 2011 Posted February 1, 2011 Rhandy, this thread is posted in the wrong forum. Customization file loaded successfully. Customization Group: ACAD Customization file loaded successfully. Customization Group: VAULT Regenerating model. Initializing.........Done. C:\Program Files\AutoCAD Civil 3D 2009\Civil\AeccUiModel.arx is an invalid ARX file. AutoCAD Express Tools Copyright © 2002-2004 Autodesk, Inc. [color=red]; error: bad character read (octal): 0[/color] AutoCAD menu utilities loaded.; error: bad character read (octal): 0 *Cancel* A drawing with this name already exists. Do you want to replace it? <N> Command: COMMANDLINE You're loading a CUI/MNU with an improperly formatted LISP, or MNL file. Edit: Don't forget to use tags. Quote
