Hello All,
I am just learning AutoLisp. So I know a little about it.
I thought of writing a program to draw a line from the intersection (if not intersecting, when they are extended) of two lines.
Thought of using Inters Function and it worked fine. But now I want to check if the selected entity is a line.
How to do that?
I wrote something like this but it fails;
(defun c:Intr()
   (Setq Line1 (car (entsel "\nSelect First Line:")))
   (CheckObject Line1)
   BLAH BLAH BLAH.....
(defun CheckObject(Enty)
 (Setq ObjType(assoc 0 (entget (Enty))))
 (if
   (/= ObjType "LINE")
   (alert "No Lines Selected... Ending")
     (exit)
Please help...
You also need to check if its a polyline and maybe explode it so you can still inters it.
Will post at work tomorrow code for this.
Check this out ......
(if (eq (cdr(assoc 0 (entget Line1)))"LINE")
 (alert "That's Right")
 (alert "I am sorry, That's wrong")
Tharwat
Wow... That Worked... Thats what I wanted.
Could you please tell me where I went wrong in my code above?
Also, If the user is not selecting a line, how can i repeat the step till he selects a line?
The ENTGET will return a list of dotted pairs; to get the type of entity use only the second item - in your excerpt code you are trying to compare a list (dotted pair) with a string; also the entity name shouldn't be enclosed in parenthesis. Please find below your corrected code:
 (Setq ObjType [color=red](cdr[/color] (assoc 0 (entget Enty))[color=red])[/color])[color=red] ;(Enty)))))[/color]
 (if
   (/= ObjType "LINE")
     (exit)
Regards,
Mircea
Oh.... I got it.. Thanks a lot...!!!:)
This one to force the user to select only a line ....
(while
   (not
       (and (Setq Line1 (car (entsel "\nSelect First Line:")))
            (eq (cdr (assoc 0 (entget Line1)))"LINE")
 (prompt "\n Please select Line onle !!!")
Thanks tharwat313....
Hmm... This is why I like this forum the most... Someone helps me out in no time, always.
You're welcome any time. :)
Regards,
Tharwat
