Hi All,
I have an image attached to the autocad using mapiinsert command.
When i select the image i would like to read the name and extension of the image.
Is there a way to this.
Thanks,
Kumar.
Not sure about AutoCAD Map – but for raster images inserted in plain AutoCAD you can use the below code:
(vl-load-com)
(setq theImage
     (cdr (assoc 1 (entget (cdr (assoc 340 (entget (car (entsel)))))))))
(setq thePath      (vl-filename-directory theImage)
     theExtension (vl-filename-extension theImage))
Regards,
Mircea
When you select the image on screen you should see its name in the properties window. If you have quick properties switched on you will see the name there.
(setq theImage
This really helps me.
Thank you all.
Sound good! You're welcome!
Regards,
Mircea
(vl-load-com)
(setq theImage
(entget nil) ? :)
Perhaps this may be a more viable solution:
(defun c:FOO (/ e v)
 (vl-load-com)
 (if (and (setq e (car (entsel "\n  >>  Select an Image: ")))
          (= "IMAGE" (cdr (assoc 0 (entget e)))))
   (prompt
     (strcat
       "\n  >>  Image Name  >>  "
       (vla-get-name (setq v (vlax-ename->vla-object e)))
       "\n  >>  Image Ext.  >>  "
       (vl-filename-extension (vla-get-imagefile v)))))
 (princ))
