svorgodne Posted January 24, 2011 Share Posted January 24, 2011 By mistake someone was defining on my team a UCS that has a "Z" axis not perpendicular to the World UCS, so everything that was drawn under this UCS is wrong and therefore not possible to fillet lines or flatten text and it is a major problem. All I need for the time being is an autolisp function that identifies defined UCS with this mistake and delete it. Apparently trying to filter through Group Codes with a dotted pair is not supported, so I don't know how to make it work due to the fact I have many drawings to fix. Any suggestion? Thanks in advance Quote Link to comment Share on other sites More sharing options...
MSasu Posted January 24, 2011 Share Posted January 24, 2011 Use the TBLOBJNAME function to access the associated list for each saved UCS (parsed with TBLNEXT) – after, by checking the vectors stored under DXF codes 11 and 12, will be able to see if the Z axis is perpendicular on XoY plane of WCS or not. By the way, you may ask moderator to move your thread to AutoLISP, Visual LISP & DCL. Regards, Mircea Quote Link to comment Share on other sites More sharing options...
