oonan Posted January 25, 2011 Posted January 25, 2011 Hello: I´m mexican, so excuse me my english. I need your help, I work as Road Engineer and I draw my design. But it's so heavy, I'm drawing a horizontal signing plans, but i think it's possible draw with Lisp muy case, it's about de Gore area, it's an area with slanted lines. I leave an example to give you an idea! Thanks for your attention!! SIGNING.zip Quote
BIGAL Posted January 25, 2011 Posted January 25, 2011 (edited) 1 make outside a polyline then just "list" it, area and length given 2 The chevrons if drawn as plines 0.2 wide you can get a total of all of them in one go then multiply total length by 0.2 for area, search here not sure maybe "total" lisps that add up objects for you. 3 our chevrons match the edge lines 100mm wide and are in autocad terms are cut parrallel to edge line 100mm offset so we use hatch solid, again you can add all these up with a lisp. 4 I will see if I can find a chevron hatch lisp it would be good for us also. Any one out there ? Searched "Total" gave lots to pick from maybe http://www.cadtutor.net/forum/showthread.php?41972-Lisp-to-add-amp-total-every-line-pline-on-a-layer&highlight=total Edited January 25, 2011 by BIGAL total search Quote
