harilalmn Posted January 25, 2011 Posted January 25, 2011 Hi All, I was trying to write a function to draw the basic outline of staircase. One or two times it worked perfectly for me. But after that it just draws some crap. Could anyone look into the code below and suggest something? (defun c:Stp() (setq Point (getpoint "\nPick a Point:")) (setq Rise (getdist "\nEnter rise of each step:")) (setq Tread (getdist "\nEnter tread of each step:")) (setq Nos (getint "\nEnter number of steps:")) (setq LandingAt (Getint "Number of steps in first flight:")) (setq P1 (list (car Point) (cadr Point))) (setq LandingLength (getdist "\nEnter Length of Landing:")) (setq n 0) (While (< n Nos) (if (<= n LandingAt) (Progn ;If True (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 0 Tread) ) ) (progn ;Else (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 (GetRad 180) Tread) ) ) ) (command "LINE" Point P2 P3 "") (Setq Point P3) (setq n (1+ n)) );While Ends );STP Ends ;======================================:::::: ;Function to Convert Degrees to Radians:::::: ;======================================:::::: (defun GetRad(Ang) (/ (* 3.14 Ang) 180) ) Quote
MarcoW Posted January 25, 2011 Posted January 25, 2011 My first idea without further looking (little time): localize your variables. Also turn of osnap when doing things like this. Quote
Tharwat Posted January 25, 2011 Posted January 25, 2011 It worked for me but you did not keep a space between the routine name and the following parens . (defun c:Stp() Should be like this . (defun c:Stp () (defun GetRad(Ang) Should be (defun GetRad (Ang) Besides that , Please localize your arguments . It's good practice buddy. Regards, Tharwat Quote
harilalmn Posted January 25, 2011 Author Posted January 25, 2011 Sure I will... This is my 4th day after I started learning Autolisp seriously from scratch... Hence any advices I would get here would be of great value..!!! Thanks a lot... Quote
MarcoW Posted January 25, 2011 Posted January 25, 2011 (edited) Just had the urge to do this: (defun c:Stp (/ Point Rise Tread Nos LandingAt P1 LandingLength n P2 P3 OsmodeOld) (setq Point (getpoint "\nPick a Point:") Rise (getdist "\nEnter rise of each step:") Tread (getdist "\nEnter tread of each step:") Nos (getint "\nEnter number of steps:") LandingAt (Getint "\nNumber of steps in first flight:") P1 (list (car Point) (cadr Point)) LandingLength (getdist "\nEnter Length of Landing:") n 0 OsmodeOld (getvar "OSMODE") ) ;_setq (setvar "OSMODE" 0) (While (< n Nos) (if (<= n LandingAt) (Progn ;If True (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 0 Tread) ) ;_setq ) ;_progn (progn ;Else (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 (GetRad 180) Tread) ) ;_setq ) ;_progn ) (vl-cmdf "_.LINE" Point P2 P3 "") (Setq Point P3 n (1+ n) ) ;_setq ) ;While Ends (setvar "OSMODE" OsmodeOld) (princ) ) ;STP Ends ;======================================:::::: ;Function to Convert Degrees to Radians:::::: ;======================================:::::: (defun GetRad (Ang) (/ (* 3.14 Ang) 180) ) ;|«Visual LISP© Format Options» (120 2 2 2 nil "Ende von " 100 9 0 0 0 T T nil T) ;*** DO NOT add text below the comment! ***|; Does it work like you want to? Edited January 25, 2011 by MarcoW Code edited Quote
harilalmn Posted January 25, 2011 Author Posted January 25, 2011 Still OSMODE was not set when I did it. I set it to '0' at the beginning and it it worked. Thankyou MacroW for the revised code...!! Quote
MarcoW Posted January 25, 2011 Posted January 25, 2011 You are right, too much hurrie is no good, code above is updated. Quote
harilalmn Posted January 25, 2011 Author Posted January 25, 2011 Thankyou All, I modified my code, atlast, like this; (defun c:Stp (/ Point Rise Tread Nos LandingAt P1 LandingLength n P2 P3 OSM) (setq Point (getpoint "\nPick a Point:")) (Setq OSM (getvar "OSMODE")) (setvar "OSMODE" 0) (setq Rise (getdist "\nEnter rise of each step:") Tread (getdist "\nEnter tread of each step:") Nos (getint "\nEnter number of steps:") LandingAt (Getint "Number of steps in first flight:") LandingLength (getdist "\nEnter length of the landing:") P1 (list (car Point) (cadr Point)) n 0 ) ;_setq (setq LandingDrawn 0) (While (< n Nos) (if (<= n LandingAt) (Progn ;If True (if (eq n LandingAt) (Progn (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 0 LandingLength) ) ;_setq );Prgn Ends (progn (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 0 Tread) ) ;_setq );Progn Ends );If Ends );Prgn Ends (progn ;Else (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 (GetRad 180) Tread) ) ;_setq ) ;_progn );If Ends (If (eq n LandingAt) (Progn (command "_.LINE" Point P2 P3 "") (setq Point P2) (Setq n (1+ n)) ) (progn (command "_.LINE" Point P2 P3 "") (setq Point P3) (Setq n (1+ n)) ) ) ) ;While Ends (setvar "OSMODE" OSM) ) ;STP Ends ;======================================:::::: ;Function to Convert Degrees to Radians:::::: ;======================================:::::: (defun GetRad (Ang) (/ (* PI Ang) 180) ) Quote
MarcoW Posted January 25, 2011 Posted January 25, 2011 Okay. But I would end with "(princ)" else ithe routine will return the OSMODE variable. ... (setvar "OSMODE" OSM) [color=darkorange][b] (princ) [/b][/color]) ;STP Ends Was fun to do, just a learner myself ;-) Quote
Tharwat Posted January 25, 2011 Posted January 25, 2011 This would avoid any mixing up with snap points . (command "_.LINE" [color=red]"_non" [/color]Point [color=#ff0000]"_non" [/color]P2 [color=#ff0000]"_non"[/color] P3 "") Tharwat Quote
vk shetty Posted August 23, 2023 Posted August 23, 2023 On 25/01/2011 at 16:30, MarcoW said: Just had the urge to do this: (defun c:Stp (/ Point Rise Tread Nos LandingAt P1 LandingLength n P2 P3 OsmodeOld) (setq Point (getpoint "\nPick a Point:") Rise (getdist "\nEnter rise of each step:") Tread (getdist "\nEnter tread of each step:") Nos (getint "\nEnter number of steps:") LandingAt (Getint "\nNumber of steps in first flight:") P1 (list (car Point) (cadr Point)) LandingLength (getdist "\nEnter Length of Landing:") n 0 OsmodeOld (getvar "OSMODE") ) ;_setq (setvar "OSMODE" 0) (While (< n Nos) (if (<= n LandingAt) (Progn ;If True (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 0 Tread) ) ;_setq ) ;_progn (progn ;Else (Setq P2 (polar Point (GetRad 90) Rise) P3 (Polar P2 (GetRad 180) Tread) ) ;_setq ) ;_progn ) (vl-cmdf "_.LINE" Point P2 P3 "") (Setq Point P3 n (1+ n) ) ;_setq ) ;While Ends (setvar "OSMODE" OsmodeOld) (princ) ) ;STP Ends ;======================================:::::: ;Function to Convert Degrees to Radians:::::: ;======================================:::::: (defun GetRad (Ang) (/ (* 3.14 Ang) 180) ) ;|«Visual LISP© Format Options» (120 2 2 2 nil "Ende von " 100 9 0 0 0 T T nil T) ;*** DO NOT add text below the comment! ***|; Does it work like you want to? Hi can we do including rebar details using same lisp.???? Quote
Nikon Posted August 24, 2023 Posted August 24, 2023 What is this request for? "Enter Length of Landing". There is no reaction to entering values. Quote
Steven P Posted August 24, 2023 Posted August 24, 2023 14 hours ago, vk shetty said: Hi can we do including rebar details using same lisp.???? Might be better to start a new thread unless the rebar refers to a staircase Quote
BIGAL Posted August 25, 2023 Posted August 25, 2023 So you want us to do the structural design of a concrete staircase yeah now worries Quote
vk shetty Posted September 1, 2023 Posted September 1, 2023 Please anyone can give the auto lisp code of this video . Quote
Steven P Posted September 3, 2023 Posted September 3, 2023 Might be an idea to look at the website in the video, see if the LISP is available there? Quote
