Diast Posted January 25, 2011 Posted January 25, 2011 I have a lisp routine that I put into the start up suite (it is still there) a few months ago. I opened Appload to use it today and it "can't be found". It is on the list in the Appload window under "loaded applications" but it is a lightened text that cannot be picked. I have opened an old dwg. to see if it works there but it does not work there either. Hope this is an easy fix. Thanks, Diast Quote
JPlanera Posted January 25, 2011 Posted January 25, 2011 you must make sure that the location of the lisp is included in the support file search path under OPTIONS Quote
BlackBox Posted January 25, 2011 Posted January 25, 2011 I do not reccommend the use of Appload. I would remove this item from your startup suite. Instead, if you know where the souce .LSP file is saved, add this statement to your ACADDOC.lsp file: (load "[color=red]FilePathGoesHere[/color]\\[color=blue]FileName[/color].lsp") Note - AutoCAD sees a single backslash "\" as two "\\" Hope this helps! Quote
Diast Posted January 25, 2011 Author Posted January 25, 2011 It is included in the support file search path under options. It is still located in the same place. Quote
BlackBox Posted January 25, 2011 Posted January 25, 2011 Perhaps the source code has been modified (i.e. commented out, etc.), can you post it (the code)? Quote
Diast Posted January 25, 2011 Author Posted January 25, 2011 Shut everything down. Went to the window and looked out at the fog (kinda like inside my head today) for a couple of minutes and fired things back up. It's now working. I don't know how that works but can now get back to the project. Thank you for taking the time to help. Quote
