Does some one know how to modify the _EXPORTSETTINGS options from lisp?
I checked the help and there is no reference to variables.
Here is the help:
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%202010%20User%20Documentation/index.html?url=WS1a9193826455f5ff-3a17572711da7b6e15f-6f29.htm,topicNumber=d0e240366
I want to enable line merge and not include layer info.
EDIT
I think I found a work-around using the plotter dwg to pdf.pc3 and editing the plotter.
The layer information options are hidden in the custom properties.
Edited by CADkitt
What are you plans for that command ?
I mean what do you want to get after all ?
I want to export a certain layout with a certain template to a certain pdf file ;)
I already do this with png out so to pdf should be damn easy.
And it already works but I only need to tweak the pdf printer a bit.
