muck Posted February 1, 2011 Posted February 1, 2011 AutoCAD 2010 vba In VBA I want to test to see if I have a valid filename before I save a drawing file using ThisDrawing.SaveAs Drawingfile. VBA needs to know if it has a valid file name "DrawingFile" before trys to save the filename. Is there a way to test for a valid filename in vba? Thank you, Quote
BIGAL Posted February 6, 2011 Posted February 6, 2011 You have the filename just check the characters in it for invalid characters such as !@#$%^&*() no easy way. Quote
