My workspaces has disappeared.
Hi
I´m using Autocad Architecture 2011. Suddenly all of my workspaces (2D Drafting and Annotation, 3D Modeling and AutoCad classic) disappeared, and now I only have architecture left. When I installed the program there was a pulldown menu called workspace in the upper left corner containing 2D Drafting and Annotation, 3D Modeling and AutoCad classic. That one is gone aswell. When i enter the CUI menu I can see that the workspaces still exist but I don´t know how to get them back. How do I get my workspaces back and how do I get the pulldown menu back? The pulldown menu workspaces doesn´t exsist in the Customize Quick Access Toolbar.
thank you in advance
Laurits
Sorry, working from home with a netbook, so its kind of difficult to provide pictures. But if you type in wssettings at the command line, you can verify that all the workspaces are checked to be displayed. to add the workspace pulldown back to the QAT, you can use the cui editor to drag and drop the command to the qat (in the cui, not the actual qat). you want Workspace control.
ACA2011 has a Classic workspace? I thought you had to run it as vanilla AutoCAD to have Classic (unless someone added it to your ACA manually)
  • 2 months later...
Laurits,
As I see you work with ACA 2011, so you can retrieve workspaces by picking the gear icon on the right hand of status line. You don't need it visible in menus.
P.S. I tried to attach images to illustrate my post, but no success. What is wrong? Is it for CADTutor's restrictions?
Edited by Ahankhah
Check to see if your profile has changed......... Tools-Options-profiles
