Rhayes Posted September 25, 2008 Share Posted September 25, 2008 I use AutoCAD Architecture 2008 and Adobe Acrobat 7.0 Pro. I can make a PDF File from a .DWG file with no problem. The Problem comes in when I take my PDF file and send it to our OCE 700 plotter the tags on the drawing get filled in black.??? The tag does have a wipeout attached to it and it view fine in the PDF itself just not when you take the PDF and try and plot it.??? I have also tried to plot from Adobe Reader 8 & 9 with the same result.??? Quote Link to comment Share on other sites More sharing options...
NBC Posted September 25, 2008 Share Posted September 25, 2008 Try plotting from AutoCAD instead then ? Quote Link to comment Share on other sites More sharing options...
Rhayes Posted September 25, 2008 Author Share Posted September 25, 2008 I can print from AutoCAD Fine. The problem is that i need to send Consultants PDF Plans. and they get black tags.???? Quote Link to comment Share on other sites More sharing options...
NBC Posted September 25, 2008 Share Posted September 25, 2008 Plead innocence ! Is it really YOUR problem if they cannot print out PDF files ? Quote Link to comment Share on other sites More sharing options...
Rhayes Posted September 25, 2008 Author Share Posted September 25, 2008 I understand what you are saying. However my problem comes in when I have to send PDF files to our Print house who can only print PDF files. Quote Link to comment Share on other sites More sharing options...
neekcotrack Posted September 25, 2008 Share Posted September 25, 2008 I understand what you are saying. However my problem comes in when I have to send PDF files to our Print house who can only print PDF files. I would make the plot in cad. Then use a program to convert it to pdf. If you need to make it half scale us another program to scale down. I think its easier that way cuz I use multibatch, to make my plots. I use Powerprint to make pdfs. Quote Link to comment Share on other sites More sharing options...
happyunited Posted September 25, 2008 Share Posted September 25, 2008 Plot your dwg to dwf then to pdf. That should sort out the problem with wipeouts. Quote Link to comment Share on other sites More sharing options...
rustysilo Posted September 25, 2008 Share Posted September 25, 2008 I understand what you are saying. However my problem comes in when I have to send PDF files to our Print house who can only print PDF files. The print house can only print pdf's??? That's very odd. They should at least have the capability to print .plt files. I'd give that a shot. Quote Link to comment Share on other sites More sharing options...
Martini Posted September 25, 2008 Share Posted September 25, 2008 I used to have that problem at my last place, and it turned out to be the plotter, the memory in the plotter would get lost or crypt and it would print lines out of wack and big black rectangles all kinds of funky crap Quote Link to comment Share on other sites More sharing options...
rustysilo Posted September 25, 2008 Share Posted September 25, 2008 You could also try a different .pdf creater like CutePDF or PDFCreator. Yet another option would be to replace your wipeouts with a hatched rectangle or lwpolyline with thick width set to a color with a 0% screening. Quote Link to comment Share on other sites More sharing options...
Gary_W Posted October 1, 2008 Share Posted October 1, 2008 Plot your dwg to dwf then to pdf. That should sort out the problem with wipeouts. This is what I have to do. I "Publish" to a DWF file, then print to PDF from the DWF file. It also makes the PDF file much smaller. Gaz... Quote Link to comment Share on other sites More sharing options...
