W-block & macro
Jkos
Hello
First time posting to this forum, I am working on AutoCAD 2011 and creating a custom button for my company, I have one problem, does anyone know how to insert a w-block with a macro?:?
Thanks on forehand// Håkan (Jkos)
Welcome to CADTutor!
-insert will use the command line. Then you will need the path to the DWG.
Are you trying to insert a Block or a WBLOCK?
Thanks for the quick reply, it is a wblock, that is why I can´t use –insert, the button should work even if the drawing have been purge, and –insert asks for a block name and not a path to the block
Thanks for the quick reply, it is a wblock, that is why I can´t use –insert, the button should work even if the drawing have been purge, and –insert asks for a block name and note a path to the block
It works for me, you will need to add an insertion point in the macro, you can use enters for the rest of the entries.
The * (asterisk) part work the way that I wanted and needed, Thanks for the help
Lucky guess. A circuit clicked in my main memory bank. SLW210 provided you with most of the help however. On behalf of us both, you're welcomed.
One problem solved, 2 arise, do any of you guys have good guide for writing macros?
I need the commands that the macro works by, example ; = enter, ^c^c is clering the command line
check AutoCAD help files it has a pretty good section on Macros
I pulled my Customization Guide for 2010 and in Chapter 4 (User Interface Customization) there is a section called Create Macros pages 161 to 177. It covers such items as an overview, basics, special characters, etc.
WBLOCK is a command name, the file created is a .dwg file. Just clarifying.
Or .dxf , many call the drawings created by the WBLOCK command "WBLOCKS" that is why I mentioned "path to the drawing" and to be certain he was wanting to insert a drawing and not a block.
Nice catch though. :thumbsup:
