samifox Posted February 9, 2011 Posted February 9, 2011 Hi, sometimes i copy the hatch from one drawing and paste it in order to compare. i noticed that the snap cant see hatch, meaning that i have to outline the hatch. is there automate way to outline hatch with a line? Thanks Shay Quote
CyberAngel Posted February 9, 2011 Posted February 9, 2011 I'm not exactly sure what you're asking, so it's hard to give advice. If your hatch is associative (usually a good idea), you can select the border along with the hatch. Go to the Options window, Selection tab, and check Associative Hatch under Selection Modes. Setting PICKSTYLE to 2 does the same thing. If you want to snap to a hatch, go to the Option window, Drafting tab this time, and uncheck Ignore Hatch Objects. Or set OSOPTIONS to 0. If you want to add a boundary to the hatch, right-click on it and select Generate Boundary, which will give you a polygon. If you do this often and you want to type in the command, you'll probably want an alias for HATCHGENERATEBOUNDARY. If I haven't answered your question properly, please state it in a different way and with more detail. Quote
samifox Posted February 9, 2011 Author Posted February 9, 2011 its exactly what i ask. but im using LT 2006. not there. Quote
SLW210 Posted February 9, 2011 Posted February 9, 2011 Your profile says AutoCAD 2010. I am rusty on 2006. What options do you get when you right click? Instead of copy, why not xref the hatch. Quote
