Hi,
I 'm new to the group. I'm hoping someone can shed some light on why I'm getting the following error everytime I run the popular free lisp routine:
; error: bad argument type: streamp nil
Thanks,
Steve
;; BOM to CSV; A program to create a csv file from a text based table in AutoCAD
;; Author: Doug Barnes
;; Company: Grantek Systems Integration
(defun Cleanup_Text ()
;; find all the text with no content and erase them
(setq nil_text
(ssget "x"
'((-4 . ""))
;; search for text with no content
(if nil_text
(command "erase" nil_text "")
;; erase text with no content
;; end cleanup_text defun
(defun Gather_Text ()
(setq Text_SS (ssget '((0 . "TEXT"))))
;; create a selection set for all text selected by the user.
;; end Gather_Text defun
(defun MakeList_X_Y_Text (Text_SS)
;; Make a list of x-coords, y-coords and text
(setq MakeList_cnt 0)
(repeat (sslength Text_SS)
(setq X_cord
(if (= (cdr (assoc 72 (entget (ssname Text_SS MakeList_cnt))))
0
;; check for the text's justification
(cadr (assoc 10 (entget (ssname Text_SS MakeList_cnt))))
;; if left justified use first alignment point
(cadr (assoc 11 (entget (ssname Text_SS MakeList_cnt))))
;; else use second alignment point
;;end if
;;end Setq
(setq y_cord
0
(caddr (assoc 10 (entget (ssname Text_SS MakeList_cnt))))
(caddr (assoc 11 (entget (ssname Text_SS MakeList_cnt))))
;;end if
(setq List_X_Y_Text
(append
List_X_Y_Text
(list
(list
(cons "X coord"
X_cord
(cons "Y coord" y_cord)
(cons "Text"
(cdr (assoc 1 (entget (ssname Text_SS MakeList_cnt))))
;;make assocation list of x, y and text dotted pairs
(setq MakeList_cnt (1+ MakeList_cnt))
;; index to next entity
;;repeat
;;end MakeList_X_Y_Text defun
(defun Sort_by_X (List_X_Y_Text)
;; re-order list from left to right
(setq X_List
(vl-sort
List_X_Y_Text
(FUNCTION (LAMBDA (E1 E2) (
;; end Sort_by_X defun
(defun Sort_by_Y (List_X_Y_Text_Col)
;; re-order list from top to bottom
(setq Y_List
(vl-sort
List_X_Y_Text_Col
(FUNCTION (LAMBDA (E1 E2) (> (cdadr E1) (cdadr E2))))
;; end Sort_by_Y defun
(defun Get_Columns (X_List)
;; determine the number of columns text
(setq Column_Qty 1
X_List_cnt 0
(repeat (length X_List)
;; add a column number to List_X_Y_Text
(setq List_X_Y_Text_Col
(append List_X_Y_Text_Col
(list (list
(assoc "X coord" (nth X_List_cnt X_List))
(assoc "Y coord" (nth X_List_cnt X_List))
(assoc "Text" (nth X_List_cnt X_List))
(cons "Column" Column_Qty)
(if (/= (nth (+ X_List_cnt 1) X_List) nil)
;; Check for end of list
(if
(- (cdr (car (nth (+ X_List_cnt 1) X_List))) Line_Tolerance)
(cdr (car (nth X_List_cnt X_List)))
;; if the X Coord of the next text is out of tolerance with the current text then increase the column count
(setq Column_Qty (1+ Column_Qty))
(setq X_List_cnt (1+ X_List_cnt))
;; index list position
;; end repeat
;; end Get_Columns defun
(defun Get_Rows (Y_List)
;; determine the number of rows of text
(setq Row_Qty 1
Y_List_cnt
0
(repeat (length Y_List)
;; add a row number to List_X_Y_Text_Col
(setq List_All
(append
List_All
(list (list ;; make a list of x, y, text, column and row
(assoc "X coord" (nth Y_List_cnt Y_List))
(assoc "Y coord" (nth Y_List_cnt Y_List))
(assoc "Text" (nth Y_List_cnt Y_List))
(assoc "Column" (nth Y_List_cnt Y_List))
(cons "Row" Row_Qty)
(if (/= (nth (+ Y_List_cnt 1) Y_List) nil)
(if (
(- (cdr (cadr (nth Y_List_cnt Y_List))) Line_Tolerance)
;; if the Y Coord of the next text is out of tolerance with the current text then increase the row count
(setq Row_Qty (1+ Row_Qty))
;; end if
;;end progn
;; end if
(setq Y_List_cnt (1+ Y_List_cnt))
;; end repeat
;; end Get_Rows defun
(defun Write_BOM_to_CSV ()
(setq Position 0)
(setq Path (getvar "dwgprefix"))
;; Obtain the file path of the drawing
(setq Dwg_Name (substr (getvar "dwgname")
1
(- (strlen (getvar "dwgname")) 4)
;; remove the .dwg from the file name
(setq BOM_CSV_File (open (strcat Path Dwg_Name " BOM.csv") "a"))
;; Open a CSV file for ammending
(while (/= (nth Position List_All) nil)
(setq Current_Row (cddr (nth Position List_All)))
;; setup to gather all of the same row text
(setq Next_Row (cddr (nth (+ Position 1) List_All)))
;; setup to check end of row
(while (= (cdr (assoc "Row" Current_Row))
(cdr (assoc "Row" Next_Row))
;; loop for all the same row
(setq Text_Column
(append Text_Column
(list (list (cdr (assoc "Text" Current_Row))
(cdr (assoc "Column" Current_Row))
;; create a list of text and column only
(setq Position (1+ Position))
;; index position in list
;; end if
(setq Text_Column
(append Text_Column
;; append Text_Column with the last text in the current row
(setq Text_Column
(vl-sort
Text_Column
;; Sort list by Column number (left to right)
(setq Column_Qty_Count
1
Write_Row ""
Column_List_Position
0
(repeat Column_Qty
;; repeat for the maximum number of columns
(if (= (cadr (nth Column_List_Position Text_Column))
Column_Qty_Count
;; check the position of the current text's postion with the column count
(progn ;; if equal string together the cuurent text and a comma
(setq
Write_Row (strcat
Write_Row
(car (nth Column_List_Position Text_Column))
(setq Column_List_Position (1+ Column_List_Position))
;; index position
;; end progn
;; if not equal string together previous text and a comma
(setq Write_Row (strcat Write_Row ","))
;; end if
(setq Column_Qty_Count (1+ Column_Qty_Count))
;; index the column count
;; end repeat
;;(print Write_Row)
(write-line Write_Row BOM_CSV_File)
;; write the current row to the csv file
(setq Text_Column nil)
;; reset for next row
;; end while
(close BOM_CSV_File)
;; close the csv file
;; end Write_BOM_to_CSV defun
;; Create a CSV file from a text based Bill of Materials in AutoCAD
(defun c:bom (/ X_List Y_List
Text_Column List_X_Y_Text List_X_Y_Text_Col
List_All
(Cleanup_Text)
(Gather_Text)
(MakeList_X_Y_Text Text_SS)
(Sort_by_X List_X_Y_Text)
(setq Text_Height (cdr (assoc 40 (entget (ssname Text_SS 0)))))
;; get the text height used
(setq Line_Tolerance (+ Text_Height (* Text_Height 0.1)))
;; set up a line spacing tolerance
(Get_Columns X_List)
(Sort_by_Y List_X_Y_Text_Col)
(Get_Rows Y_List)
(Write_BOM_to_CSV)
;; end defun
Hi Doug,
I managed to get your lisp file to work after a lot of trial and error and then stumbling across what was causing my issues by accident. The file I was in was read-only and it didn't like that fact. Once I saved to my hard drive it worked fine.
However, now I've run into another issue. I'm trying to use a lisp file called ATTDEF2Text.lsp. When I run it, it says to "Select objects", however, I can't seem to select any of the attribute blocks on my screen. Since I don't use AutoCad that much, I could be doing something way off base here. Any ideas would be greatly appreciated.
Thanks,
Steve
Hi,
Not sure how to send, so I'm copying what I found on the web below. Basically, I was able to get the BOM to CSV lisp file working on regular text on a drawing, but when I got to drawings that had these attribute lines for a drawing bill of material, I needed to try and find something that would extract the tag input values. However, not much success so far.
(defun c:AttDef2Text (/ ActDoc LayoutCol tmpLayoutBlk)
; Changes attdef entities (attributes that haven't been put into a block) into dtext
(vl-load-com)
(setq ActDoc (vla-get-ActiveDocument (vlax-get-Acad-Object)))
(vla-StartUndoMark ActDoc)
(setq LayoutCol (vla-get-Layouts ActDoc))
(vlax-for LayoutObj LayoutCol
(setq tmpLayoutBlk (vla-get-Block LayoutObj))
(vlax-for Obj tmpLayoutBlk
(if (= (vla-get-ObjectName Obj) "AcDbAttributeDefinition")
(setq TextObj (vla-AddText tmpLayoutBlk (vla-get-TagString Obj) (vla-get-InsertionPoint Obj) (vla-get-Height Obj)))
(vla-put-Alignment TextObj (vla-get-Alignment Obj))
(if (/= (vla-get-Alignment TextObj) 0)
(vla-put-TextAlignmentPoint TextObj (vla-get-TextAlignmentPoint Obj))
(vla-put-Backward TextObj (vla-get-Backward Obj))
(vla-put-Layer TextObj (vla-get-Layer Obj))
(vla-put-Normal TextObj (vla-get-Normal Obj))
(vla-put-ObliqueAngle TextObj (vla-get-ObliqueAngle Obj))
(vla-put-Rotation TextObj (vla-get-Rotation Obj))
(vla-put-ScaleFactor TextObj (vla-get-ScaleFactor Obj))
(vla-put-StyleName TextObj (vla-get-StyleName Obj))
(vla-put-UpsideDown TextObj (vla-get-UpsideDown Obj))
(vla-Delete Obj)
(vla-EndUndoMark ActDoc)
Regards,
Steve
As a quick fix. You could use the Express tools to Explode Attributes to text, then run the BOM to CSV.
How would I go about getting Express Tools?
Please advise,
Steve
