trying to revolve a main frame door corner
Hi guys,
I attached a drawing showing a main frame of a door .
What I'm not able to do is to "revolve" the upper right and left corner of this frame along the path I sketched for you.
I hope that someone of you guys looking at this file will be able to help me.
Thanks for any help.
Stefano.
prova_portone.dwg
Edited by stenews
I don't see what your attempting to revolve... Where is the Axis...?
KC
Hi kencaz and thanks for your reply!
...Where is the Axis...
well I'm attempting to extrude along a curved path.
I'd like to a make a curved architrave.... for that door frame
prova_portone.dwg
Edited by stenews
Hi SEANT and thanks for your reply
it's absolutely one of the smartest interpretation I seen before! 8)
BWT I was thinking to cut off at certain point the curve and to reach the top part in a square way
Thank you very much indeed
P.S.
could you briefly explain me how to do it by myself?
In case I decide to use your personal interpretation, how to finish to extrude the back side of it?
I created a circle (two point option) to find the center and copied that circle along the Y axis. The centers of the two circles form the axis for use with the REVOLVE command.
The lintel suggested a plane, so I cut back the region you already had in place.
@SEANT
brilliant....I got it:)
let me ask you the very last think...in case I don't want all circular but only the first part so that I can go straight on for the last part?
like I did in my proposal sketch section?
prova_portoneOption2.dwg
Can you elaborate? I don't understand what is meant by 'first part', 'last part'. What or where is the 'proposal sketch'?
@SEANT
finally I did what I was really looking for!
BTW I say many thanks to you for your help, I couldn't do that without your great help, you boast me up
prova_portone.pdf
@SEANT
sorry mate, but I need you help one more time.
Do you remember the door frame we discuss...?
well I should make to it 5 cuts per each vertical part in way that at end it should look shrink around the cut.
I can understand that my explanation will sound to you terrible unclear...but I don't know at moment how to manage my description in a way better than that
I hope you will understand me...thanks in any way
Bye,
Stefano
Yes, that description is not very clear. Can you draw what you mean? Even a 2D drawing will give us a better idea what is required.
@Sittingbull
you got it!! :)
how did you do that??
that's what I was looking for...but the horizontal section looks bit different doesn't it?
Glad you like it.
First i exploded your area, then i used pedit to make a polyline.Made an offset of that line(inwards).
Tweaked a bit and extruded the shape:wink:.
Best regards,
SB
