khoshravan Posted February 12, 2011 Share Posted February 12, 2011 I think that line weight controls line thickness in plot. If I want to see the result in paper pace, what shall I do? I should say that I also posted this question on the following forum: http://forums.autodesk.com Quote Link to comment Share on other sites More sharing options...
nestly Posted February 12, 2011 Share Posted February 12, 2011 Do you have lineweight turned on in the status bar? Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 12, 2011 Share Posted February 12, 2011 It can but it can also be overridden in your plot style (ctb or stb). Quote Link to comment Share on other sites More sharing options...
Dana W Posted February 12, 2011 Share Posted February 12, 2011 Your relative lineweight differentiation should show in paperspace the same as it looks in modelspace. However, if you have checked "Display Plot Styles" on your layout page setup dialog, the line weights might look the same weights as they are going to be plotted. The lineweight control for the screen is different than the actual plotted lineweight. The differential is heavier than actually plotted by default as a 'screen only' visual aid. This visual differential can be changed with a sliding scale button in TOOLS > OPTIONS > USER PREFERENCES > LINEWEIGHTS. Once you check off the "Display Plot Styles" selection, whatever setting you have may possibly be overridden by how your plot will actally appear. This may be why your lineweights don't seem so heavy in paperspace. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted February 13, 2011 Author Share Posted February 13, 2011 Do you have lineweight turned on in the status bar? Dear nestly Thanks for your reply. I wasn't aware of line weight button in status bar. This solved my issue. Thanks for other replies as well. Quote Link to comment Share on other sites More sharing options...
khoshravan Posted February 13, 2011 Author Share Posted February 13, 2011 It can but it can also be overridden in your plot style (ctb or stb). Dear ReMark nestly's reply solved my problem, but could you please explain what is ctb and stb? Quote Link to comment Share on other sites More sharing options...
Organic Posted February 13, 2011 Share Posted February 13, 2011 .ctb and .stb are files that contain information regarding plot styles and how the drawing should be plotted. I.e. you can define a plot style .ctb file to print all lines that are color magenta weight 0.7, all lines color green weight 0.35 etc... Quote Link to comment Share on other sites More sharing options...
khoshravan Posted February 13, 2011 Author Share Posted February 13, 2011 you can define a plot style .ctb file to print all lines that are color magenta weight 0.7, all lines color green weight 0.35 etc... Does it mean I can apply sort of filtering to plot colors and to control which color should be plotted and which one to ignore? If it is so, that's fantastic. Where can I find more info on using .ctb and .stb? Quote Link to comment Share on other sites More sharing options...
Cat Posted February 13, 2011 Share Posted February 13, 2011 Does it mean I can apply sort of filtering to plot colors and to control which color should be plotted and which one to ignore?If it is so, that's fantastic. Where can I find more info on using .ctb and .stb? http://www.caddmanager.com/CMB/2009/08/cad-standards-ctb-vs-stb/ You can also turn off plotting for individual layers if you want to see the information in the drawing file, but don't want it to plot. Quote Link to comment Share on other sites More sharing options...
