abc_123 Posted February 14, 2011 Posted February 14, 2011 hi all, any specific reason for keeping blocks in layer 0... and other out of layer 0 ??.. Quote
Tiger Posted February 14, 2011 Posted February 14, 2011 Because if the block consists soley of objects on layer 0, the block will assume the properties of whatever layer it is inserted on. If on the other hand the objects are on other layers, the components of the block will always be on those layers, and not on the layer that the block is insert on. This is best explained by doing so try it out yourself and see. Quote
designerstuart Posted February 14, 2011 Posted February 14, 2011 just to avoid misunderstanding - it is the component parts of the blocks which should (usually) be on layer 0 - the block itself can be on any layer you like. try making a few blocks on a few layers, with some objects on layer 0 and some not, then freezing off various layers. you'll (probably) find you prefer the performance of the block made the recommended way. it's good practice because it works best that way. Quote
Glen1980 Posted February 14, 2011 Posted February 14, 2011 If you copy blocks from drawing to drawing you don't get replicated or similar layer names i.e. Electrics, Electrical, electrical etc. If you want the same blocks on different viewports i.e floor plans and reflected ceiling plans you can just change the layer name of the block. I always set the colours to by block so I can make some blocks more defined than others. Quote
