sandeep410 Posted February 14, 2011 Share Posted February 14, 2011 How to do this in solid works,When i tried the ball just went through other balls.How can i make 1st ball collide with other and not pass through. For some reason i cannot select cam mates between two spheres. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted April 3, 2011 Share Posted April 3, 2011 That was done in an advanced motion study with gravity turned on. In tools>add-ins do you have Solidworks Motion? I believe that is the only way you can simulate collision and gravity. The mates you would need to add are Cam Mates between all the balls. Quote Link to comment Share on other sites More sharing options...
sandeep410 Posted April 4, 2011 Author Share Posted April 4, 2011 That was done in an advanced motion study with gravity turned on. In tools>add-ins do you have Solidworks Motion? I believe that is the only way you can simulate collision and gravity. The mates you would need to add are Cam Mates between all the balls. I tried doing it but after collision only the balls starts wobbling but i want only last ball to move like shown in video. Quote Link to comment Share on other sites More sharing options...
shift1313 Posted April 4, 2011 Share Posted April 4, 2011 Did you have a material applied to the balls? Quote Link to comment Share on other sites More sharing options...
sandeep410 Posted April 5, 2011 Author Share Posted April 5, 2011 ya i applied sam e material to all balls Quote Link to comment Share on other sites More sharing options...
shift1313 Posted April 5, 2011 Share Posted April 5, 2011 ill give it a shot when i get a chance to see if i have the same issues. You will need gravity, and a cam mate between all the balls. Your best bet is having the ball and "string" as one solid hinged at the frame so its restricted to a single axis of revolution. Quote Link to comment Share on other sites More sharing options...
