I have a table cell that contains a field linked to a block attribute.
When I use the GetCellValue method it returns the text value of the attribute.
How do I retrieve the actual field data, for example:
%%).TextString>%
I'm primarily interested in retrieving the ObjID of the block containing the attribute the field references.
Problem solved for my specific instance.
Starting with a table cell (row 0, column 0) that contains a field as formatted above:
Store a reference to the active document:
(setq activedoc (vla-get-activedocument (vlax-get-acad-object)))
Get the Table object by user selection:
(setq table-obj (vlax-ename->vla-object (car (entsel))))
Get the field ID of the cell:
(setq pfieldid (vla-getfieldid table-obj 0 0))
Convert the Field ID to an object:
(setq pobject (vla-objectidtoobject activedoc pfieldid))
Apparently field objects are not fully supported in VLISP, so I needed to get the DXF entity data of the field to continue:
(setq pdxf (entget (handent (vla-get-handle pobject))))
This is the parent field data. From here I retrieved the Child Field ename from code 360 and then the DXF entity data:
(setq cdxf (entget (cdr (assoc 360 pdxf))))
Code 331 is the ename of the attribute reference and I used this to get the attribute reference object:
(setq aobject (vlax-ename->vla-object (cdr (assoc 331 cdxf))))
Finally I retrieved the Block Reference object using the OwnerID of the Attribute Reference object:
(setq bobject (vla-objectidtoobject activedoc (vla-get-ownerid aobject)))
I only tested this on 32Bit AutoCAD 2011. For 64Bit use GetFieldId32.
Any comments would be welcomed.
