Fnuik Posted February 14, 2011 Posted February 14, 2011 Hi, In the older IE's and other browsers this type of url is no problem. http(s)://username:password@server/bron.ext But since some M$ update u cant use it anymore in IE. And yes autocad is using the IE engine. Thx btw to renderman for providing this wonderfull code (defun L12_GetFileFromURL (url path / utilObj tempPath newPath) ;; © RenderMan 2011, CADTutor.net ;; Example: (download "http(s)://username:password@server/source.ext" (getvar 'dwgprefix)) (vl-load-com) (setq utilObj (vla-get-utility (vla-get-activedocument (vlax-get-acad-object)))) (if (= :vlax-true (vla-isurl utilObj url)) (if (vl-catch-all-error-p (vl-catch-all-apply 'vla-GetRemoteFile (list utilObj url 'tempPath :vlax-true))) (prompt "\n <!> Error Downloading File From URL <!> ") (progn (if (findfile (setq newPath (strcat path (vl-filename-base url) (vl-filename-extension url)))) (vl-file-rename newPath (setq voidPath (strcat (vl-filename-directory newPath) "\\void_" (vl-filename-base newPath) "_" (menucmd "M=$(edtime,$(getvar,date),YYYY-MO-DD-HH-MM-SS)") (vl-filename-extension newPath))))) (vl-file-copy tempPath newPath) (vl-file-delete tempPath))) (prompt "\n <!> Invalid URL <!> ")) (vl-catch-all-apply 'vlax-release-object (list utilObj)) (princ) ) Is it posible to download a file from a secure http location in lisp? Or is it posible to find a workaround for my litle (LOL) problem here More info on the subject from m$ http://support.microsoft.com/kb/834489 Quote
