resullins Posted March 31, 2011 Author Share Posted March 31, 2011 You're funny, Render.... I'm a pretty quick learner... but have never really been a programmer, except for control systems. @SWL: Thanks... I'll try that. One more little issue that I've found. I've always been told that if you want to make AC load a LISP every time you start it, to put the code into accaddoc.lsp. But I don't have one. Can I just create one? I have a couple of things I want to start customizing. Quote Link to comment Share on other sites More sharing options...
BlackBox Posted March 31, 2011 Share Posted March 31, 2011 You're funny, Render.... I'm a pretty quick learner... but have never really been a programmer, except for control systems. @SWL: Thanks... I'll try that. One more little issue that I've found. I've always been told that if you want to make AC load a LISP every time you start it, to put the code into accaddoc.lsp. But I don't have one. Can I just create one? I have a couple of things I want to start customizing. Cheers, mate! Yes, ACADDOC.lsp can be created if not already present, and is loaded everytime a drawing is opened **, where as ACAD.lps is only loaded once per session. ** Edit: when found in the support files search path(s). Hope this helps! Quote Link to comment Share on other sites More sharing options...
resullins Posted March 31, 2011 Author Share Posted March 31, 2011 Gotcha. Is there anything specific that needs to be in there, or can it only be the commands I want? Like HTML, so I have to tell it to start a program.... I hope that makes sense. Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 1, 2011 Share Posted April 1, 2011 Ok, I'm ressurecting this thing in hopes that someone can help me further. I need to alter the Lisp program the very kind LeeMac provided in this thread. I simply need to remove some of the user inputs, and make them default to an attribute I dictate. Did the last code I posted not work for you? http://www.cadtutor.net/forum/showthread.php?56912-LISP-Routines-How-To.&p=388914&viewfull=1#post388914 Quote Link to comment Share on other sites More sharing options...
resullins Posted April 1, 2011 Author Share Posted April 1, 2011 No no no... the code works perfect. But the part where it asks you which attribute you want to number... I want to make it ALWAYS number the attribute LINE#... that's the only thing we'll use it for. So I'm playing with it. But even in its current form, it's saving me SO SO SO SO SO much double-click, select, backspace, tab, enter.... Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 1, 2011 Share Posted April 1, 2011 No no no... the code works perfect. But the part where it asks you which attribute you want to number... I want to make it ALWAYS number the attribute LINE#... that's the only thing we'll use it for. But the code I just linked you to doesn't prompt for an Attribute Tag Quote Link to comment Share on other sites More sharing options...
resullins Posted April 1, 2011 Author Share Posted April 1, 2011 @Lee: Apparently I was a little blonder than usual yesterday. I skipped RIGHT over that post! I'm sorry! That's great! I did add back in the part where it asks the number length... but that's awesome! Thanks! Quote Link to comment Share on other sites More sharing options...
Lee Mac Posted April 1, 2011 Share Posted April 1, 2011 No worries Quote Link to comment Share on other sites More sharing options...
