Starting VBA or VB.NET
I have a fairly solid programming background (BASIC, C++, FORTRAN, PASCAL, etc.); I've even written and edited C++ and FORTRAN programs to run under AutoCAD v12. Unfortunately, this was in a previous life (15+ years ago).
Over the past several months I've dusted off the programming cobwebs and delved into writing VBA programs for MS Excel 2007 with quite a bit of success. This has me thinking about automating a few process in AutoCAD 2009. Unfortunately, VBA for AutoCAD appears to be a completely different animal from VBA for Excel. In Excel you know where everything is; if you want to edit a certain cell, you reference that cell {Sheet1.Cells(1,1).Value=Whatever}. In AutoCAD things float around like dust motes. Also, there are countless help sites and forums with VBA Excel tips and tricks; a simple Google search will answer almost any question. VBA for AutoCAD is too specialized, and little help exists (other than "buy my program" sites).
From my searching this site appears to be the best source of code snippets, and I've learned quite a bit already. But I'd like a more robust reference source, such as a book. Unfortunately, none of the ones I've found look right for me, and all are for older versions of AutoCAD.
Questions:
- I know VBA is going away and being replaced by .NET. Is VB.NET available for AutoCAD 2009? If it is, I'd rather just start there than bother learning VBA for AutoCAD just to have to re-learn something else in a few years.
- If .NET isn't available for AutoCAD 2009, can anyone recommend a good VBA reference manual? The latest AutoCAD version as possible, I at least want to be able to look up Table information.
Some of the specific VBA projects I have in mind are stripping excess formatting data from the text in an AutoCAD Table entity (see HERE for more info), and exporting the XYZ coordinates for all PLines in a drawing to either a text (.CSV) or Excel file.
Questions:
Then .Net it is
Here is a start
Here is a link to download 2009 ObjectArx(Has .Net info also, more detail about ObjectArx, but since .Net API is just wrappers around ObjectArx is very useful)
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=785550
Link to Developer's Guide
http://docs.autodesk.com/ACD/2011/ENU/filesMDG/WS1a9193826455f5ff2566ffd511ff6f8c7ca-4875.htm
Look at DevTV: Introduction to AutoCAD .NET Programming and AutoCAD .NET Labs in Link
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1911627
Another great resource
http://www.theswamp.org/index.php?board=27.0
Link to Through the Interface by Kean Walmsley blog who is "Senior Manager of Developer Technical Services (DevTech), the worldwide team of API gurus providing technical services through the Autodesk Developer Network."
http://through-the-interface.typepad.com/through_the_interface/
Go to Online Classes then select Customization and Programming track
http://au.autodesk.com/
Don't know if this helps your look "here", but look up "styles" you can set your fonts styles to what ever you want size width font spacing etc and then just use them with one variable change just change "Textstyle" to the style you want. (setvar "textstye" "leroy")
Re the pline xy question do a bit of a search here I am pretty sure I have seen that in the last few days. may be a lisp but so what call lisps from .net
