tasld Posted February 18, 2011 Posted February 18, 2011 My old XP machine finally died. I was able to move Autocad LT 2000i, but when opened, I receive the following message: Fatal Error: Unhandled e06d7363h Exception at 75e89617h . I love 2000i and have no desire up upgrade. Is this error related to Windows 7? If so is there a fix? Thanks! Tim Quote
ReMark Posted February 18, 2011 Posted February 18, 2011 Many have tried but few have had long term success. As you know 2000i is not supported under Windows 7. Try a search on the error at the AutoDesk website. Let us know what you come up with. Quote
dugg Posted February 19, 2011 Posted February 19, 2011 Check out this thread and see if any of the links will help out. http://social.answers.microsoft.com/Forums/en-US/w7programs/thread/709e0d9c-d4ab-4e6e-93a9-de64712a71cd I loved 2000i also. Quote
tasld Posted February 23, 2011 Author Posted February 23, 2011 Thanks for the replies. After several days and countless hours I have solved the problem. First, you need Windows 7 pro, this allows you to run windows XP virtually (pretty neat!). While in XP virtual mode, I was able to move AutoCad 2000i with PC Mover. It works great! Window Pro cost me $89.99 to upgrade from Windows 7 home, PC mover was $39.99. Much cheaper than AutoCad Lt 2011 or buying used software from questionable sources. Hope this helps someone else. Quote
ReMark Posted February 23, 2011 Posted February 23, 2011 That information will be very useful I'm sure. Thanks for sharing the solution with us. Quote
