olecarman Posted February 21, 2011 Posted February 21, 2011 I want to set my "dimension style manager" and make it stay somewhat permanent in its settings. However, seems like it will change from time to time to another setting, and I have to repick the settings again. Why does it change and how can I stop it from changing as I do all of my drawings the same way all the time and want the setting to stay permanent. Aggravating to have to change them back from time to time... Thanks olecarman Quote
Sittingbull Posted February 21, 2011 Posted February 21, 2011 When does it change? Are u using a template on startup? Make a new empty drawing, define all needed settings (like dimensions, layers, linetypes...) and save it as *.dwt in your template folder. In your options, go to the "Files" Tab, under Template settings, get the path for your default template for QNEW. Hope this helps. SB Quote
