AutoCAD 2010.
Is it possable for VBA to do a Plot Previous simular to the Plot Previous in the AutoCAD Plot Menu
pull down menu. If so, does any one have the code for it.
Thank you,
I could use the lisp routine ;Previous Plot
(defun c: PP()
(Command "-Plot" "No" "" "Previous Plot" "" "No" "No" "Yes")
Then maybe used send command in visual basic but it is not adviseable to use send command in
vba so is there a way to use VBA only with plot previoius?
Thank you,
