rexanteria Posted February 22, 2011 Posted February 22, 2011 how can i use my newly downloaded fonts into autodesk 2008?? is it possible?? please help... i have downloaded a dingbat fonts.tff is it possible that i can use it in autocad 2008?? Quote
Sittingbull Posted February 22, 2011 Posted February 22, 2011 Did you install it? Does it work in any other program? Quote
Organic Posted February 22, 2011 Posted February 22, 2011 Put it in the fonts folder of AutoCad (or whatever folder your AutoCad fonts directory in the Options points to). Quote
ReMark Posted February 22, 2011 Posted February 22, 2011 how can i use my newly downloaded fonts into autodesk 2008?? is it possible?? please help... i have downloaded a dingbat fonts.tff is it possible that i can use it in autocad 2008?? Are you sure it is TFF and not TTF? TTF is the file type for TrueType Fonts. Quote
Tharwat Posted February 22, 2011 Posted February 22, 2011 how can i use my newly downloaded fonts into autodesk 2008?? is it possible?? please help... i have downloaded a dingbat fonts.tff is it possible that i can use it in autocad 2008?? Try it , why not . And you'll see if it is possible or not . Add your fonts into the following folder and re-start Autocad . C:\Program Files\AutoCAD 2008\Fonts Good luck buddy. Tharwat Quote
ReMark Posted February 22, 2011 Posted February 22, 2011 Sorry guys but I have to disagree with you on this one. If it is a TrueType font it should be put in the Windows/Fonts folder and not in the AutoCAD/Fonts folder. How to install TrueType fonts on your computer. http://desktoppub.about.com/cs/fixfonts/ht/install_fonts_w.htm Quote
