orange Posted February 25, 2011 Posted February 25, 2011 is there parameters manager for autocad 2009? can parameters manager solve my 'mathematical problem': I need to assign a value to pline called 'real_length' and 'startvalue' autocad then calculates endvalue=startvalue-real_length*attenuation. and displays result on the end of pline. Quote
Rebel Posted February 25, 2011 Posted February 25, 2011 If you are looking for a text object to display the length of your line, I believe this can be accomplished with a dynamic block with the stretch function, and an attribute nested within set with a field to reflect the length. I'll give it a test run and report back Quote
Organic Posted February 26, 2011 Posted February 26, 2011 Something like this? Either I don't know how to use that or I can't get it to work. You could certainly do this with a pretty simple LISP script. Quote
Rebel Posted March 2, 2011 Posted March 2, 2011 Either I don't know how to use that or I can't get it to work. You could certainly do this with a pretty simple LISP script. Sorry to bump this but I didn't catch the last post. Insert that as a block, and when you lengthen the line with the dynamic grip the attribute contains a field that will display the length of the line upon regen. Quote
