Grigs Posted February 25, 2011 Posted February 25, 2011 I am using 2006/2007 and have some blank tables I use. When I want to add a row, the text for the new row defaults to a different style and size. How can I get it so it uses the correct font and text size? Quote
Organic Posted February 26, 2011 Posted February 26, 2011 You could modify/create a Table style (Format -> Table Style) and apply that as the default for all rows in the table. I just tried what you are trying to do in AutoCad 2010 however and if I manually modify the properties of a row, right click on that row, Inset new row, the new row does have the same properties (text height, colour, etc) as the modified row (i.e. the formatting is not lost). Quote
Grigs Posted February 26, 2011 Author Posted February 26, 2011 When I set the text style and size of all the cells then add a row, it reverts back to the STANDARD font (not the one I use) and a different text size. Quote
Organic Posted February 26, 2011 Posted February 26, 2011 Are you highlighting one of the rows you have formatted when you then try to insert a new row? Quote
Grigs Posted February 26, 2011 Author Posted February 26, 2011 Yes. Just one of the cells, not the entire row. Just tried it and doesn't matter. Quote
