feeneyje Posted April 3, 2006 Posted April 3, 2006 How do I scale an image in the X-direction but not the Y-direction. Thanks for your help, Jeff Quote
feeneyje Posted April 4, 2006 Author Posted April 4, 2006 I found the solution. Turn your drawing into a block, then when inserting the block you can set the scale in the X,Y, and Z directions seperatly. Jeff Quote
mistrymah Posted August 21, 2010 Posted August 21, 2010 Hi, I tried this on my end however, scale does not give the exact size in "Inches", I want to set the image for the tile of 2'x1', the was of in size of 10" length and 8" breadth when I initially inserted through "attach Image" option, i converted into this a Block and while inserting what I should put in x and Y to get the block with size of 2' x 1' .. please help... thanks for your help Quote
Dana W Posted August 21, 2010 Posted August 21, 2010 See this thread > http://www.cadtutor.net/forum/showthread.php?51657-Scale-a-block-in-one-way-direction-(x)) Quote
