we have autodesk map-5 and land desktop 3... autocad 2002... client sent us a shape file and all the other files that correspond to it... how do i open this file and use it as a dwg to modify
LOAD to load the shx file then SHAPE on the command line.
Edited by SLW210
i tried.. we have .shp, .shx, and all the other files... doesnt work... when i key in LOAD, it asks for the shape file and i select it.. but it tells me .shx is a normal text font file, not a
shape file. and does not give me the option to select the .shp file
just now.. bunch of jibberish i dont understand...
ÿÿþp n A;ˆ_ý A }/žñ¤ A;òî A
%´M–¾
I don't know if this command is available for such old versions, but have you tried the MAPIMPORT command?
That is how I import all of my GIS Shapefiles into my drawings.
I totally forgot GIS uses a different type of shape file. Should open with MAP.
No worries.
... or Land desktop. :wink:
sweet jesus it worked... thanks guys
i had tried that MAPIMPORT once already, but didnt pay attention to changing the file type at the bottom to a shape file...there are also other files in the zip we got...
.dbf
.prj
.sbn
.sbx
do they work with the shape file, or do we do something different with them
Simply open a new drawing, execute the MAPIMPORT command, and select your Shapefile (.shp)... be mindful of the end result you need, as you may need to bring in the Object Data during subsequent Window options.
Otherwise, you should be good.
