how do one wants to do a polar increment angle to make a degree in a autocad drawing. Le'ts say i want to design a truss but at the angle of the truss , i have no idea how to make an angle between the top chord and lower chord. which icon i should click on ?? and how?? thanks.:(
option 1: Set your Polar Tracking (right-click on the POLAR-button at the bottom of the screen) to a suitable angle and draw away
option 2: when in the Line or Polyline command, type
option 3: Draw lines based on coordinates if you have them, or relative coordinates.
Does any of the above options strike your fancy?
If you are new to AutoCAD you should try going through the Tutorials available here at CADTutor from the beginning to the end.
