I have just started converting some VBA to .net. In my code I had put
Application.AcadApplicaton.ZoomExtents
and it was working. Yesterday I started adding new code and discovered that the ZoomExtents was no longer working. VS2008 doesn't give an error but the routine is no longer doing it's job. Does anyone have any suggestions?
Thanks
Rose Anna
Is it not in extents already?
I don't really understand. I am running a .net program in debug mode. The de****** automatically opens a drawing, then I do netload and load the .dll, then I run a command that creates objects and adds to the document/transaction. After the command has run, I need to run zoom extents to get a full view of the drawing. The command can create the same drawing but different sizes for the objects. I did try to change the template I used to include ANSI standards and changing dimensions attribute but that shouldn't have anything to do with the zoomextents command ????
Dim acDoc As Document
acDoc = Application.DocumentManager.MdiActiveDocument
Dim acCurDb As Database
acCurDb = acDoc.Database
Using acTrans As Transaction = acCurDb.TransactionManager.StartTransaction()
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
Dim acModelSpace As BlockTableRecord
acModelSpace = acTrans.GetObject(acBlkTbl(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
dim radCir = inputA
Dim acCirc1 As Circle = New Circle()
acCirc1 .SetDatabaseDefaults()
acModelSpace.AppendEntity(acCirc1 )
acTrans.AddNewlyCreatedDBObject(acCirc1 , True)
acCirc1 .Center = New Point3d(0, 0, 0)
acCirc1 .Radius = radCir
acTrans.Commit()
Application.AcadApplication.ZoomExtents() ''' This is the command that no longer works ????
End Using
Thanks
How very interesting. My code is now working. I reset my autocad system to not use ANSI standards. Any insights??
