herb6874 Posted March 4, 2011 Posted March 4, 2011 Good morning Fellows is it possible to switch back and for from CTB to STB, or I need to have two templates one for each? We use the same template to start a dwg and some clients want them to with CTB others with STB. Please help HR Quote
rkent Posted March 4, 2011 Posted March 4, 2011 If you don't have layers already created in the template then you can convert as needed from one to the other. I would have the layers with the stb plot style names in another drawing (you may need one per client if they use differing style names) and drag and drop those in as needed in the stb based drawing. Have another .dwg file with layer names you can drag and drop for the ctb based drawings. Thinking about it more I believe it would be simpler to maintain two template files, one for ctb and one for stb. Quote
